![]() | Home > Technical (L322) > Water leaking into the cabin, right B-pillar |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
door seal? ... - .- -.
Shogo Member Since: 01 Jan 2015 Location: Sweden Posts: 61 ![]() ![]() ![]() |
the door seal is fine. acctually seems to come from the seem between the inside roof and the B-pillar trim.
i think they might be .. ... - .- -.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Sunroof drains blocked? |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Windscreen not sealed properly ? . |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
^^it will be one of those 2, has it had a replacement screen at any point? should say land rover pilkington, anything else is a replacement. If it has just started doing it then my money is on the sunroof, as the screens tend to leak from day 1 they are fitted and if they don't then its unusual for them to develop a leak over time |
Thanks for the ideas !..
Birdbrain Member Since: 19 Nov 2014 Location: Cheshire Posts: 74 ![]() ![]() ![]() |
Mine had the same problem and when I climbed up to look at the sun roof the offside drain was blocked. No amount of poking around with a piece of wire would free it so I crawled underneath. It turns out the air reservoir (I'm assuming it was for the suspension) was stopping the little rubber discharge valve from the roof drain working properly. I loosened the brackets and moved it slightly and got a face full of stinking water for my pains but the problems now cured. |
