Home > Technical (L322) > Hesitaion/misfire at 50MPH |
I can think of two things,
27th Apr 2015 10:06am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Does it do it at the same speed in 4th ?? if it does it's not likely to be the engine... or does it do it at the same revs in forth ?? in which case it might be the engine, if it doesn't do it at all in forth then it's more than likely the gearbox or other drivetrain issue...
27th Apr 2015 11:42am |
ksmith100 Member Since: 20 Apr 2012 Location: Stirling(ish) Posts: 77 |
Hi Pete,
27th Apr 2015 2:25pm |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
I once had a similar sounding problem on a Fiat Coupe - slight misfire at a specific rpm, only happened on very light throttle, turned out to be a coil pack problem
27th Apr 2015 10:07pm |
Thanks to all those that have answered.
30th Apr 2015 9:11am |
