Home > Maintenance & Mods (L322) > Rear Washer wont stay primed? Here's a fix for �2.75 !
jon3929
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
Ok so I know its hardly a massive issue, but I was a little grumpy that having eventually got the rear wiper and washer working and not leaking, the washer wouldn't stay primed, so I bought a new Land Rover one-way valve for �7.99 Confused
And the result..... exactly the same, it wouldn't stay primed, so the wiper was still doing one and a half wash cycles before any sign of water.... Sad
A quick search on the flea bay and I found item number eBay Item No. 261513780860
A 6mm one way valve for �2.75 delivered. The 6mm variant fits perfectly.
Fitted in 5 minutes.
And the result...... perfect Thumbs Up
Stays primed and washes instantly. �2.75 well spent for anyone who has the same irritation Very Happy
Cheers, Jon.
Post #320080 27th Mar 2015 7:21pm
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
Mine does the same and because of this it has scratched the rear screen. Silly question but where and how do you fit this? Many thanks
Post #320325 29th Mar 2015 2:16pm
jon3929
Hi, it is a direct replacement for the original one-way valve located a couple of inches from the wiper motor in the water supply hose. You need to remove the interior cover for the wiper motor to get access (see the wiki). The new unit looks like this once installed.
Cheers, Jon.
Post #320334 29th Mar 2015 4:31pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Would have thought swapping the OEM valve ( in line just before the wiper motor) would have been the right place.
The top internal shroud would need to be removed to access the pipe work and motor . It's easy enough so long as you don't break the plastic tongues that fix the cover to the door
Edit..sods law you answer just as I'm trying Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #320336 29th Mar 2015 4:34pm
Jimmy C
United Kingdom 2003 Range Rover Vogue Td6 Zambezi Silver
Sold out of 6mm already Neutral
Post #320736 1st Apr 2015 7:55am
PM me your address - I bought a pack of 4 as they had sold out of singles
Post #320746 1st Apr 2015 8:50am
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
I will have one if you got a spare also mate let me know.
Post #320753 1st Apr 2015 9:27am
Jimmy C
With thanks to Alistair I now have rear washer that stays primed "perfect" such an easy fix, how come LR couldn't get it right???
Post #322755 15th Apr 2015 8:52pm
Thumbs Up I haven't got round to fitting my own yet
Post #322767 15th Apr 2015 9:22pm
steve9bug
Or sending mine LOL
Post #322769 15th Apr 2015 9:29pm
It went at the beginning of last week - the other 2 arrived Big Cry
Post #322770 15th Apr 2015 9:33pm
steve9bug
No probs mate see if I gets here I will let you know might just be a bit snail mail this way on Wink
Post #322774 15th Apr 2015 9:49pm
Garyfax
England 2009 Range Rover Vogue SE TDV8 Santorini Black
Sorted mine yesterday. Took 15 mins
and works perfect. I even bought a
new wiper.
Thanks for the eBay link.
Post #322867 16th Apr 2015 6:32pm
Mike.Boro
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
Nice fix Very Happy Mine hasn't work in years, 5 mins to do, cheers Jon Thumbs Up
Post #324342 25th Apr 2015 2:53pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Bit more than 5 mins but got it done Thumbs Up Thanks for the tip! 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #325959 4th May 2015 3:02pm
