Home > Camping, Caravanning and Holidays > Tin Tent imminent
Page 1 of 3 123>
steadyaway
Tin Tent imminent
After a few years off from caravanning we have decided to start again now we have the full fat. We pick the van up in a couple of weeks and the tow bar is being fitted Monday. I have decided on the Weastfalia detatchable one with 13 pin electrics and the LR loom. Am I right in thinking that once it is all fitted I need to have it enabled or is it plug and play?
Post #323889 23rd Apr 2015 9:42am
Both sir... Whistle
Will work plug & play but i think there are certain types of electrics that need programming for features to work sir Rolling Eyes ...
Post #323892 23rd Apr 2015 9:51am
steadyaway
Thanks Craig. As I understand it with the 13 pin and the LR loom it locks the suspension and also affects the engine management to give the best performance for towing. I'll take it in just to make sure.
Post #323893 23rd Apr 2015 9:54am
Post #323907 23rd Apr 2015 10:37am
IanT599
Does the computer still need to be enabled if you switch from 2x 7 pin to 13 pin?
Post #323939 23rd Apr 2015 12:20pm
steadyaway
As far as I am aware, if the trailer ECU has been enabled previousley (for the 7 pin wiring) then it is just a case of replacing it with a 13 pin harness. The consensus seems to be to go with the LR loom. A little bit more expensive bur better quality.
Post #323956 23rd Apr 2015 12:52pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
steadyaway wrote:
Thanks Craig. Also affects the engine management to give the best performance for towing.
Not too sure about that, can anyone confirm this? It does lock the air suspension at the standard setting though as confirmed with the indicator locked light in the centre of the main control switch.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #324042 23rd Apr 2015 7:50pm
IanT599
My old D3 did alter the transmission when towing.
I remember collecting a sankey trailer with it and it always dropped a gear very early on hills even if it didn't really need to. I used to drive it in command shift/manual mode after that as the trailer was empty and the D3 certainly never struggled. Mine was an 08 so not sure if still the same on a FFRR
Post #324048 23rd Apr 2015 8:04pm
mzplcg
I recall if it's not programmed on the car then the car's fog lights will still come on. If programmed correctly they don't if you're towing, only on the trailer. Rear fogs obviously.
Post #324054 23rd Apr 2015 8:43pm
steadyaway
It's also supposed to deactivate the rear parking sensors when reverse is selected. I've only heard about the engine/gearbox management thing from the tow bar fitter so I stand to be corrected. But he's has had 3 range rovers so I would guess he knows a bit about them.
Post #324058 23rd Apr 2015 9:03pm
IanT599
What caravan are you getting?
Post #324076 23rd Apr 2015 10:19pm
n1cktdv8
Dedicated loom, without doubt. It;s not cheap but it is good. Just a light on the dash, no annoying buzzer in the boot like on a non-dedicated loom.
Deffo worth it. Is this where I put the car details and a bit about myself ?........
Post #324078 23rd Apr 2015 10:31pm
steadyaway
Oops quoted the wrong post. Sorry.
Post #324092 24th Apr 2015 5:53am
steadyaway
Try again. Stubby fingers, phones and early mornings don't mix!
It's a Swift Charisma 545 Ian.
Post #324093 24th Apr 2015 5:54am
steadyaway
Well, not really good news today. Took the ff for its tow bar fitting this morning. Decided to have the Westfalia detachable fitted with 13 pin electrics. Looks good and really easy to attach and detach. Then I went to my local indy LR to have the towing ECU enabled. After a short while he came out and told me that there was no configuration file for the 2006 MY. All the relays and fuses are present but when he plugs the MOT tester into the socket the car displays "Check Trailer Lights" or something similar, and the lights on the tester flash instead of lighting up constantly. So, should it be "Plug and Play" or do I have issues. It's going back Wednesday morning for the wiring checking out.
Post #324648 27th Apr 2015 6:50pm
Page 1 of 3 123>
