Home > Camping, Caravanning and Holidays > Tin Tent imminent |
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 |
After a few years off from caravanning we have decided to start again now we have the full fat. We pick the van up in a couple of weeks and the tow bar is being fitted Monday. I have decided on the Weastfalia detatchable one with 13 pin electrics and the LR loom. Am I right in thinking that once it is all fitted I need to have it enabled or is it plug and play? |
23rd Apr 2015 8:42am |
Thanks Craig. As I understand it with the 13 pin and the LR loom it locks the suspension and also affects the engine management to give the best performance for towing. I'll take it in just to make sure. |
23rd Apr 2015 8:54am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16305 |
23rd Apr 2015 9:37am |
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 |
Does the computer still need to be enabled if you switch from 2x 7 pin to 13 pin? |
23rd Apr 2015 11:20am |
As far as I am aware, if the trailer ECU has been enabled previousley (for the 7 pin wiring) then it is just a case of replacing it with a 13 pin harness. The consensus seems to be to go with the LR loom. A little bit more expensive bur better quality. |
23rd Apr 2015 11:52am |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 |
Not too sure about that, can anyone confirm this? It does lock the air suspension at the standard setting though as confirmed with the indicator locked light in the centre of the main control switch. Steve. 1968 Series IIA Pastel Green, nearly there project |
23rd Apr 2015 6:50pm |
My old D3 did alter the transmission when towing.
23rd Apr 2015 7:04pm |
I recall if it's not programmed on the car then the car's fog lights will still come on. If programmed correctly they don't if you're towing, only on the trailer. Rear fogs obviously. |
23rd Apr 2015 7:43pm |
It's also supposed to deactivate the rear parking sensors when reverse is selected. I've only heard about the engine/gearbox management thing from the tow bar fitter so I stand to be corrected. But he's has had 3 range rovers so I would guess he knows a bit about them. |
23rd Apr 2015 8:03pm |
What caravan are you getting? |
23rd Apr 2015 9:19pm |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
Dedicated loom, without doubt. It;s not cheap but it is good. Just a light on the dash, no annoying buzzer in the boot like on a non-dedicated loom. Deffo worth it. Is this where I put the car details and a bit about myself ?........ |
23rd Apr 2015 9:31pm |
Oops quoted the wrong post. Sorry. |
24th Apr 2015 4:53am |
Try again. Stubby fingers, phones and early mornings don't mix! It's a Swift Charisma 545 Ian. |
24th Apr 2015 4:54am |
Well, not really good news today. Took the ff for its tow bar fitting this morning. Decided to have the Westfalia detachable fitted with 13 pin electrics. Looks good and really easy to attach and detach. Then I went to my local indy LR to have the towing ECU enabled. After a short while he came out and told me that there was no configuration file for the 2006 MY. All the relays and fuses are present but when he plugs the MOT tester into the socket the car displays "Check Trailer Lights" or something similar, and the lights on the tester flash instead of lighting up constantly. So, should it be "Plug and Play" or do I have issues. It's going back Wednesday morning for the wiring checking out. |
27th Apr 2015 5:50pm |
