Home > Technical (L322) > Spare key problem
Nigwell
United Kingdom 2013 Range Rover Vogue SDV6 Indus Silver
Spare key problem
Tried my spare key this morning would not open the car of the button unlocks doors manually but car starts beeping,put key in ignition but will not turn off insert position. Any ideas guy is it just a battery replacement,car is an 08 with the flip type key.
Post #323703 22nd Apr 2015 4:41pm
wealy
Battery
Post #323812 22nd Apr 2015 9:40pm
might need a re-pair, but you'll have to do all the keys ... ... - .- -.
Post #323865 23rd Apr 2015 7:06am
Nigwell
Thanks guys is a job for me or the stealership ?
Post #323971 23rd Apr 2015 12:59pm
i'm sure i've seen the procedure on the forum somewhere, hopefully someone will post a how to.. ... - .- -.
Post #323972 23rd Apr 2015 1:14pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
Isn't it something to do with turning and holding the key in the lock? Ring any bells? I had to do it on one of my very early L322s
Post #323985 23rd Apr 2015 2:51pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
This is how I did mine when I got the new keys from Daveo
Reset Procedure for your key fobs
Every signal from the remote handset contains the transmitter identification code and a rolling code. The BCU checks
the codes and only responds if the signal is from a valid transmitter. During vehicle production, the remote handsets
supplied with the vehicle are initialised to set their individual transmitter identification codes and synchronise their
respective rolling codes with the BCU. If a transmitter loses synchronisation with the BCU, or if a replacement or
additional remote handset is to be used with the vehicle, the initialisation procedure must be repeated. During the
procedure, all remote handsets for use with the vehicle must be initialised.
Initialisation Procedure
1 Ensure the vehicle is unlocked and the driver and front passenger doors are closed.
2 Install a key/remote handset in the ignition switch, then turn the ignition switch to position I and back to position
0 in less than 5 seconds to put the BCU into the initialisation mode. Continue the procedure within 30 seconds
of turning the ignition switch to position 0.
3 Remove the key/remote handset from the ignition switch.
4 Press and hold the unlock button for a maximum of 15 seconds. During this time, momentarily press the lock
button three times within 10 seconds.
5 Release both buttons.
6 Successful initialisation is indicated by the BCU locking then unlocking the vehicle. If this does not occur, repeat
step 4.
7 Repeat steps 4 and 5 with all other remote handsets belonging to the vehicle (4 maximum). Begin the
initialisation of each remote handset within 30 seconds of completing the previous initialisation, or the BCU will
drop out of the initialisation mode and the complete procedure will have to be started again.
Maybe different for the later keys as mine still had the BW type key although it is a facelift with touch screen and the AJV8 engine. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #323987 23rd Apr 2015 2:58pm
Weegie
I used this method. Search was my friend in finding it again. Whistle
step 4.
When doing the second key don't put it in the ignition but, as above, go from step 4.
Beat me to it rej. Thumbs Up Smile John
GAP iiD BT
Post #323988 23rd Apr 2015 3:00pm
wealy
Change the battery before you do any of that.
Post #323999 23rd Apr 2015 3:34pm
wealy
Post #324004 23rd Apr 2015 3:38pm
Nigwell
Looks like I a visit to the stealership for a jumpy like me 😀
Post #324030 23rd Apr 2015 6:09pm
