Home > In Car Electronics (L322) > Knakered Radio |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16267 |
Probably the Bluetooth module has water in it? The left side of the boot leaks and if one unit on the M-O-S-T ring stops working then your symptoms are what are usually reported sir... |
21st Apr 2015 9:31pm |
winslo Member Since: 12 Sep 2011 Location: Morpeth, Northumberland Posts: 135 |
i checked the back and no water in sight?
21st Apr 2015 9:32pm |
First things first sir...You need to work out which component in the M-O-S-T ring has failed! I mentioned the BT module as its on the top of the stack and most common for water ingress failure, but you say yours is dry... |
21st Apr 2015 9:37pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
I would check all the fuses first, make sure that they're not blown and that they work (i.e. test the fuses on a multimeter).
22nd Apr 2015 11:34am |
I pulled the plugs out of the Bluetooth and it seems there is some water ingress in there, as some holes/pins are white and corroded
24th Apr 2015 8:39am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35248 |
from memory someone here used a cut down 'bic' pen [without the insides] to do this ... ... - .- -.
24th Apr 2015 8:46am |
found it,
24th Apr 2015 8:47am |
Buy one of these... A must for the home FFRR mechanic...
24th Apr 2015 8:53am |
Its fixed
25th Apr 2015 8:40am |
