2003 RR entertainment system fault | |
Ok, so had a bit of water ingress in the boot, which resulted in corroded terminals on the modules.
The main ones affected are the DSP which has 1 pin broken, never affected the speakers or anything as such (probably the reason for the cd changer not working) and the other module is the silver box, one black plug and one blue plug with 2 small antennae connectors I assume they are. Again, 1 pin broke on this which resulted in the screen either not working or flickering.
So replaced this module and now the screen works great, no flickering. However it no longer gives the menu for dsp, sat nav and the radio does not work.
been to LR today for a diagnostic plug in and they can't pin point the problem. they are assuming it is now a faulty display. which i can't see it being as it is all working. just no sound from the speakers and not seeing the nav and dsp menus on the home screen
