![]() | Home > Maintenance & Mods (L322) > Filler cap retainer strap replacement |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3894 ![]() ![]() ![]() |
So this is irritating me, although I have never (yet) dropped the filler cap:
So I thought I'd repair, cut the ends clean, slid on heat shrink sleeving, tacked the ends together with super glue, then liberally applied rubber solution, slid the heat shrink into place and shrank it - worked but not entirely satisfactory:
Then I thought, you have dozens of tape recorder drive belts from a previous life, replace the strap! So I cut a drive belt to length, crimped on some "eyes" on the ends, removed the plastic filler cap cover (easy) and refitted as shown - decent job, now I can't drop the filler cap and scrabble around on the floor in the petrol station to retrieve it, even if I wanted to - and i can't think why I would.
Its as good as the original and it cost next to nothing ![]() |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
that is a top repair |
I can easily supply the belts, each belt will do this mod at least 3 times. Just checking with Stan where I stand re: forum rules etc. Geoff |
I've had the go ahead from Stan if you want a drive belt please gift �1 via PayPal to geoffsmi@gmail.com and put your address in the comments and I'll post 'em out. The �1 is for p&p and the belt.
will have one pls Geoff.
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
Now that's a top idea, mine bust and never thought about replacing or fixing it as my other motors don't have this kind of set up, but I like the fix |
�8.00 for a new cap...or it was in October 2012 |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
Unnecessary quote removed
Good point re black paint but I was in a rush, also it's not a self tapper it's a threaded screw (M4) that fits perfectly tightly in the hole (oh err missis) and is tightened so the thing still swivels. I think a self tapper would do in fact thinking about it I have some black ones - doh! |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
And a little black shrink wrap over the crimp |
Thanks Craig - its a mod to simply stop the filler cap from falling to the ground and maybe even getting lost or broken - it works and it looks better than a bit of snapped rubber. Black paint and shrink wrap notwithstanding |
To subtle for you this morning then Geoff... ![]() No reference to rear spoilers at all sir ![]() ![]() ![]() ![]() ![]() |
^ sound like a good story here Craig..... |
Im saying nuffing |
