Home > Technical (L322) > Juddering / Smoking / Engine Problem
davidjpowell
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
Car has developed a problem after I probably drove it harder than normal.
Juddering at around 2 - 2.5K
Difficult to start when cold with Diesel Knock.
Garage expected injector fault - but the fault moves around from injector to injector.
They've mentioned loom and ECU as maybe's. Trying to get some ideas and worst cases on cost......
A photo of the sad trip home!
Post #321973 9th Apr 2015 7:35pm
davidjpowell
No reply, but just in case anyone looks this is what a diesel engine does with petrol in it apparently.
Post #322032 10th Apr 2015 11:23am
ebajema
My first thought would have been fuel pump but petrol in a diesel (apart from small amount in winter) is not a good thing. Own fault or did someone else fill it up ?? MY 2010 5.0 SC Galway green and sand interior!!
Post #322034 10th Apr 2015 11:35am
davidjpowell
The wife.
Fortunately we were planning ahead and filling up early so it would have been a 50/50 mix. Specialist say's it's running fine although might bring an early injector failure on....
Post #322037 10th Apr 2015 11:41am
ebajema
Did they empty the tank and then refill ? MY 2010 5.0 SC Galway green and sand interior!!
Post #322038 10th Apr 2015 11:45am
davidjpowell
Emptied whole system.. Changed filter. Run through 3 lot's of specialist additive. refilled with another lot of additive.
Post #322041 10th Apr 2015 11:49am
ebajema
And it didn't run on the mix for too long I guess. Lets hope the adverse effects are very limited. Glad it is sorted though Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #322042 10th Apr 2015 11:54am
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Does the TD6 not have the yellow flap thing to stop you putting petrol in it? 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #322046 10th Apr 2015 12:16pm
davidjpowell
Not having done it myself I don't know - but would assume not. I am surprised as it's bloody hard work to get the diesel nozzle in and always assumed that there was some anti-misfuel device in place.
Post #322050 10th Apr 2015 12:24pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
The wrong nozzle detection came with the TDV8. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #322056 10th Apr 2015 12:42pm
