Home > Technical (L322) > No power to fuse 51? Engine cut out
William97841
This might get people thinking...engine just cut out found out that no power to fuel pump relay in back with ignition on...also no power to fuse 85 and fuse 51??? Td6 cranks over lovely 100amp fuse is fine.
Its a nice lovely problem motor.
lol any help
Post #321993 10th Apr 2015 12:23am
William97841
Any know where r116 relay is?? Because I think that's got something to do with it
Post #321994 10th Apr 2015 12:29am
William97841
Any help??
Post #323836 23rd Apr 2015 12:06am
It's at connection C1895 in the waterproof box under the bonnet... the blue relay...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #323838 23rd Apr 2015 12:34am
Have you tried Fuse 15?
Post #323861 23rd Apr 2015 7:56am
William97841
Hi well I've changed that blue relay but when this happens I don't get any power to the glow plug/black connector cable...what comes through the back of the e box?? Then I pull some red cable from behind the battery and fuel filter primes and then power to fuse 51...so I'm a bit stuck...replaced the red cables into the e box still doing it...so I'm lost
Post #323916 23rd Apr 2015 11:19am
Sounds like a lose red cable behind the battery then, take the battery out and have a good look.... Pete
Post #323931 23rd Apr 2015 11:58am
William97841
Yep it is a lose connection because when I cable tie the red cable to the front bolt holding the battery it's ok. But I got a feeling it's something lose below the transfer box ecu...where those 100amp fuses are...anyone had a problem with those??
Post #324487 26th Apr 2015 10:33am
