Home > Technical (L322) > Month 4 of ownership - my first proper fault/problem! |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
1. The air suspension will shut down to a failsafe position if the min brake fluid alarm is raised. Sort out the leak and all should be well with the air. The HDC alarm is probably just part of the chain of bongs you get with this also.
5th Apr 2015 11:12pm |
As the HDC uses the ABS it will also be deactivated until the leak is fixed.
6th Apr 2015 5:17am |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 744 |
4 months without a fault Chris , better than D2s...................................
6th Apr 2015 8:14am |
sass Member Since: 23 Apr 2014 Location: Helsinki Posts: 30 |
The brake lines are probably corroded. Happened to me in February. One way to test this is to push the brake pedal and if it keeps on sinking, the there is likely a problem with the lines. I was told that this is a common fault in regions where they use salt on the roads. There is a "trap" underneath the car where the brake lines can mature to the point of failing completely. It is not an expensive job, but I would not recommend driving the car to the garage. |
10th Apr 2015 11:41am |
