Home > Technical (L322) > Parking sensors inop
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
Hi Tom,
Did you ever get your water dammaged module replaced?
I have same issue with water ingress & they won't replace under warranty, no major but wondered if you established the cause? As I don't want to replace then it fail again, or worse!!! 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #321029 2nd Apr 2015 7:15pm
billcyn
United Kingdom 2008 Range Rover Vogue TDV8 Epsom Green
Had a similar problem with front & rear sensors not working - just a beep and front PDC switch illuminated.
Fault was a single wire to N/S rear sensor broken. As there are 3 wires for each sensor, finding the culprit was not easy but a new wire soldered in place cured the problem. NB this is a rear bumper off job!
Post #321057 2nd Apr 2015 10:34pm
