![]() | Home > Technical (L322) > Fault Codes P132A & P132B - Turbo Actuator? |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 ![]() ![]() |
Split hoses cause the same fault to be logged
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
Thanks for the reply Mikey.
1959terry Member Since: 28 Apr 2014 Location: London Posts: 128 ![]() ![]() ![]() |
I have the same fault however mine is only when starting. Is this a turbo acctuator replacement or could it be lubricated in some way?
XJRSuper Member Since: 20 Jul 2015 Location: Wales Posts: 7 ![]() ![]() |
Hi All
Just had mine serviced at main dealer and asked them to lubricate the actuators. Didn't make any difference. They did say that there are new modified actuator rods which should fix the problem 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 ![]() ![]() ![]() |
From my experience with both issues, the problem and codes are different.
Yep it's the TDV8 unfortunately! Damn thing failed literally as I ordered my L405. Evidently sulking, still want to keep it though as it's a great machine, but not keen to spend a fortune. Any estimates on what you'd expect this to cost? 2015 Range Rover SDV8 Vogue SE |
The parts for the actuators are super cheap. It's just 2 connecting rods.
The actual issue is the electronic actuators apparently rather than the rod itself. Sounds like the labour is still hefty, but getting the actuators reconditioned. Apparently going to cost around £100 each to do that, plus a day or two of labour. At least the turbos don't have to be replaced! 2015 Range Rover SDV8 Vogue SE |
TJ101 Member Since: 10 Apr 2012 Location: Taunton Somerset Posts: 32 ![]() ![]() |
Morning all
