Home > Technical (L322) > Parking assist module water ingress |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 |
Hi guys,
1st Apr 2015 3:00pm |
Thats odd nearly always a sensor or the loom that needs replacing. If fault shown is more than one sensor faulty then its usually the loom. |
1st Apr 2015 3:20pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
i'd find out where this module is and inspect around that area for any other damage and try and find out where this water is coming in ... ... - .- -.
1st Apr 2015 3:23pm |
They said there was no sign of water around it but when they took module out it was full of water & they suggested that there may have been a water leak previously that's been repaired, they checked with previous dealer that all history is with & they've not done any work on leaks.
1st Apr 2015 4:47pm |
a 2012my shouldnt leak and i concur with your suggestion that over zealous pressure washing could have caused it if, some other bits in tgat area were wet.. ... - .- -.
1st Apr 2015 6:10pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
That's very strange, it's attached to the back of the fuse box in the boot, if it had water inside from a leak then there would be a lot more around the fuse box... Early cars can rust out through the bottom of the rear wing but yours should be OK....
1st Apr 2015 6:13pm |
Thanks for the suggestions guys, I'll check it out once I've got it home & feed back.
1st Apr 2015 6:20pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Traditionally LR only sell rain capes for the nearside.....this is a new one on me! Land Rover Addict
1st Apr 2015 6:24pm |
I'm going on my 03 one and yes I had to remove the fuse box to get to it, just a few screws... didn't have to unplug anything to turn it enough to see the unit... yours might have far more stuff in there so take a few pics before you have a go at it..... Pete
1st Apr 2015 6:28pm |
Found my module easy enough, it's in left rear quater behind the removable panel & directly accessible. Had a good root arround today & found no signs of water leaking in to rear quater or sitting there, only evidence was 2 bolt heads directly below the module. Floor was bone dry & it's rained all day been for a run about & still none.
3rd Apr 2015 7:13pm |
Yep, looks like you've found the problem... and does look like condensation... maybe a bag of silica gel in the new one?? Pete
3rd Apr 2015 10:37pm |
Many thanks to Dan @Duckworth for supplying a replacement genuine module, speedy delivery & far cheaper than the dealers
11th Apr 2015 5:15pm |
