![]() | Home > General > Battery flattened by radio.. |
Herdwick Member Since: 05 May 2010 Location: Lake District, Cumbria. Posts: 36 ![]() ![]() ![]() |
Had same problem on my last one.
I thought the car would protect its self from this by shutting down or did you have the ignition on as well ?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 ![]() ![]() |
i ad a similar problem, i was fitting leds and kept on switching the ignition on [not starting engine] and off quite a few times ..went to start the car , battery flat, left for 2 hours and it was ok...i think its the first signs of a battery giving up ... ... - .- -.
I've sat on the side of the motorway with the radio, side lights and hazards on for 3 hours and was able to start up afterwards. I've also run the park heating (max a/c button, not pre-heater) for a couple of hours.
doublejay Member Since: 08 Nov 2009 Posts: 131 ![]() |
yep - found that one out today... leaving the ignition in II (that's the last position before crank) keeps everything active.....radio with play for ages, but take the keys out ![]() |
td6 vogue Member Since: 31 Dec 2009 Location: essex Posts: 93 ![]() ![]() ![]() |
Yeap mines been like that from new, hence never listen to the radio when car not on. annoying as i like the radio on when i wash the thing! |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
Got back from a weeks holiday yesterday, went to collect the RR from the long stay car park, t had 1 flat tyre, 2 soft tyres and a flat battery. Looks like it's new battery time. It's gone flat in under 10 mins before with the doors open and radio on when hoovering it out.
Am I the only person here who has flattened a radio with a battery?
