Home > Maintenance & Mods (L322) > A few add ons |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
Not seen these door pins before made of steel and carbon fibre look with Land Rover on top and the illuminated plates :
26th Mar 2015 6:04pm |
scotbruce Member Since: 06 Dec 2014 Location: Aberdeen Posts: 39 |
26th Mar 2015 8:42pm |
It always deadlocks first time so it's no issues and have you tried said way on these new rangeys as an ex twoc'a its nigh on imposs to have away _____________________________________________________
26th Mar 2015 8:49pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3742 |
Thieves are not always after the vehicle - just the contents - plus not all MY's deadlock on the 1st press of the button 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
26th Mar 2015 9:05pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Don't they deadlock every time you lock them using the remote? Thought the pins were pretty much redundant these days |
26th Mar 2015 9:06pm |
Think mine deadlocks only on 2nd press? - 2009 reg 2010MY VSE. |
26th Mar 2015 9:10pm |
No they don't Craig - some MY's deadlock on the 1st press of the button, the later ones don't and require two presses to deadlock and engage the interior sensors. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Must be a setting in the CCF then as my 2012 does on the first lock press (i tested it as i was paranoid about the thefts a few months ago) |
26th Mar 2015 9:29pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35293 |
my 2009my superlocks on one press...if pressed again within 10 secs the internal detection sensor is switched off.. ... - .- -.
26th Mar 2015 9:36pm |
Yes, same as my set up Stan... |
26th Mar 2015 9:53pm |
Do they illuminate Scott? How did you wire them? |
26th Mar 2015 9:54pm |
Back to the manual ...
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 |
Mine doesn't dead lock on a single press.... |
26th Mar 2015 10:05pm |
There wired into the two dash interior bulbs by drivers and pass leg :we got the superior cam tech versions lucky us eh Craig _____________________________________________________
26th Mar 2015 10:18pm |
