Home > Maintenance & Mods (L322) > Pray for me please |
My money would be on a ball joint. I had this set of symptoms on an old Rover SD1 and it was the lower arms. Not worn enough to show with a pry bar but rattling like a can of nails when cornering. Hellish vibration through the wheels too.
25th Mar 2015 2:21pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Back in the day I would have removed a half shaft and rear prop and stuck the centre difflock in - that would tell you if it was the rear diff!!! Land Rover Addict
25th Mar 2015 3:07pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3241 |
How do you stand if he's wrong? John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
25th Mar 2015 3:12pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1257 |
@ Weegie.
25th Mar 2015 3:16pm |
HalifaxMark Member Since: 03 Feb 2015 Location: Halifax and / or Civray France Posts: 14 |
I didn't ask ! I thought about it - a lot.
25th Mar 2015 3:19pm |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 |
I have a very similar issue with my tdv8. On fast slight left handers the whole car shakes like hell, scared my brother to death when he drove it. Lower arm has been replaced and all tyres and wheels changed but problem still exists. |
25th Mar 2015 3:54pm |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Its fair to say that GO have always played fair with me....They've given loads of advice FOC and seem genuine.
25th Mar 2015 3:57pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2660 |
Jeez, I had the exact same symptoms & it was a dicky caliper. |
25th Mar 2015 4:34pm |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
Is it possible to disconnect the rear diff and drive on the front axle to rule out the diff.Am not sure it is but am sure someone will know.Certainly does not sound like diff to me,it could be anything.What about the props or the transfer box or an electronic fault.Anyone got a 4 wheel rolling road you could put it on!! |
25th Mar 2015 7:35pm |
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 |
It still sounds to me not diff related, if the diff was locked up because the electronic locker has failed then its still not going the cause the wheels to wobble, the inside (of the corner) tire can skip and chirp on hard tight corners
25th Mar 2015 10:24pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 |
Hmmm. while the car is waiting for the back-ordered diff, has the garage got another car in, that he could just disprove the 'dodgy wheel' theory, and swap wheels set from another car, and retest ???
26th Mar 2015 12:08am |
jon3929 Member Since: 01 Jan 2015 Location: Weston Super Mare Posts: 62 |
PM sent. Its impossible that the diff can cause the symptoms you describe. Don't spend a penny until you've had wheels balanced on a "Hunter GSP9700 Road Force balance & measurement" machine.
26th Mar 2015 8:42pm |
Thanks Guys, I have spoken to GO and asked them to change all the Discs first and balance the wheels again before the Diff arrives from LR ( on backorder until 20th April ). The discs were on their way out anyway so at least that's money well spent. Will keep you informed. |
27th Mar 2015 9:54am |
it seems that there's a lot of money being spent! |
27th Mar 2015 6:28pm |
