Home > Maintenance & Mods (L322) > ZF 5HP24 Transmission rebuild - How To ? It begins..... |
Good on you Pete. It really isn't that difficult although to be honest the ones I did were years ago in the days of 3 speeds and brake bands rather than clutch packs. But having read RRPHIL's thread about tearing down the 6HP26 I would definitely have a go.
20th Mar 2015 7:10am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Thanks chaps.
20th Mar 2015 12:42pm |
I must admit to having the same feelings really, I bought the rad above mainly because it was reduced to £20 and I couldn't resist the bargain!!!!
20th Mar 2015 7:54pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 963 |
Pete,
24th Mar 2015 2:20pm |
Cheers Phil, had read about the problems with not getting the TC back on right, measuring should sort it... thanks for the tips about the screws....
24th Mar 2015 6:35pm |
No - just undo the 9 bolts and pull.
24th Mar 2015 8:15pm |
Started the strip out mid morning Thursday, get FF on ramp, leave key in the ignition but switch off, wait 10mins then disconnect battery so the electronic steering lock is free...
28th Mar 2015 6:29pm |
Well done so far Pete.
28th Mar 2015 10:46pm |
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 118 |
Really enjoying this topic.
30th Mar 2015 4:52pm |
RRPhil, will get the valve body sent off tomorrow, cheers....
31st Mar 2015 3:36pm |
Dean Member Since: 23 Mar 2014 Location: Glasgow Posts: 51 |
Brilliant read as ever.
31st Mar 2015 7:01pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Good luck with that Pete. |
31st Mar 2015 7:26pm |
Starberg Member Since: 08 Jan 2015 Location: Karlskrona Posts: 70 |
Brilliant thread! Good luck Haylands L322 Vogue 2003 |
31st Mar 2015 7:35pm |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 313 |
This is a great, informative thread. Blow by blow with 'Dr. Phil' keeping a beady eye on proceedings. Keep it up |
31st Mar 2015 7:37pm |
