Home > Technical (L322) > Air con
Nigwell
United Kingdom 2013 Range Rover Vogue SDV6 Indus Silver
Air con
The air con In my car never seems cold,set it to low and no difference then after a few mins it starts blowing then a few mins later stops again. If I put max air con on it blows good and cold.
Post #319236 23rd Mar 2015 3:42pm
Probably low on gas, it's the first thing to check..... Pete
Post #319282 23rd Mar 2015 7:08pm
what is the little dial under the centre vents set at? If it is in the centre of red blue then the air from the facia vents will be slightly warmer, than you expect on all but max, set it to the cold/blue side and the air from the centre vents will be fully chilled. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #319293 23rd Mar 2015 7:54pm
Nigwell
Gas is ok and the dial set on blue,just does work as should.
Post #319301 23rd Mar 2015 8:31pm
