Home > Technical (L322) > Air con |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
Probably low on gas, it's the first thing to check..... Pete
23rd Mar 2015 7:08pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8513 |
what is the little dial under the centre vents set at? If it is in the centre of red blue then the air from the facia vents will be slightly warmer, than you expect on all but max, set it to the cold/blue side and the air from the centre vents will be fully chilled. There is nothing that can't be fixed with a hammer😜😜
23rd Mar 2015 7:54pm |
Nigwell Member Since: 01 Jan 2015 Location: Cannock Posts: 91 |
Gas is ok and the dial set on blue,just does work as should. |
23rd Mar 2015 8:31pm |
