Home > In Car Electronics (L322) > Questions about upgraded head unit |
Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138 |
The previous owner (or the one before him) in 2008 or thereabouts upgraded the head unit in my car to a Kenwood touch screen all singing and dancing unit - DVD/Satnav/CD/Radio with ipod and usb connectors (although I cant find the usb wire and the ipod seems to be for an older model) with remote and headrest screens - and installed a Parrot hands free kit as well
22nd Mar 2015 1:34pm |
Don't know about non standard stuff, but if you disconnect the battery or pull the right fuse at 12 o'clock, the clock will go to 12 when the power comes back.....
22nd Mar 2015 2:31pm |
Thanks for that - I shall take a look later and sort the clock out |
23rd Mar 2015 2:04am |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 337 |
have you tried to update the Parott firmware? You can do this via Bluetooth on a PC and the instructions are on their website.
23rd Mar 2015 9:22am |
Tried and failed the only laptop I have with Bluetooth is a windows 8.1 and it simply won't connect or even see the parrot - I also tried an older windows 7 laptop but it refused to play ball as well (I am an IT technician so would know my way about these things) I gave up at that point but I think I have a laptop in the workshop that might do the job - I'll get a look later and see if it helps |
23rd Mar 2015 12:14pm |
Same as me really so what you will have to get is a "parrot update cable"
23rd Mar 2015 12:40pm |
I'd imagine somebody somewhere has one of those lying in a drawer not being used (a bit like the specialist tools needed to work on some cars) and the day I would buy a cable said somebody would post here going "I have one you can borrow" I'll hang on to see if the laptop I have will work (I'm just waiting on a new hard drive to arrive for it) before looking for a cable |
23rd Mar 2015 4:41pm |
I usually end up throwing old cables and leads out and you can bet within 24 hours of doing so i will get a phone call asking if I have one |
23rd Mar 2015 5:09pm |
And at least the hands free issue is solved Took the laptop out and tried again and this time (for whatever reason) everything worked fine. The software updated ok and once my phone connected it synchronised and now works fine without me having to connect it manually every time.
23rd Mar 2015 10:55pm |
