![]() | Home > Technical (L322) > LED Headlight rings |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1750 ![]() ![]() ![]() |
Can anyone tell me if there is a specific setting for the headlights to just have the LED rings switched on..? I have a great desk top wallpaper with a 2010 MY car with just LEDs shown as lit but with my DLRs the dip beam light is on and so are the LEDs around the main beam (I think its the main beam anyway)
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
IID tool, CCF files> DRL settings > Set to "standard" and they will be on |
Your welcome Ash |
Hmm. Will have a proper look later on but at first glance i can only see Canadian or Scandinavian DLR enable feature. No standard one to enable (unless it comes with standard turned on by default which can't be disabled? Ash
philbathurst Member Since: 28 Apr 2013 Location: Iver Posts: 138 ![]() ![]() ![]() |
you need to update your IId tool BT to the latest firmware - then you will see the option for just DRL's as well as the other two options |
I already have V3.00 on the IID. I think this is the latest version ?? Ash
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35526 ![]() ![]() |
it does appear to be the latest version.. ... - .- -.
I updated a couple of weeks ago to V3.19 or something similar, I just connected to the updater to check if I had the latest version and it updated it. the app has been updated by GAP, I then checked the changed screen layout and noticed the other DRL setting in the ccf settings
