Home > Technical (L322) > LED Headlight rings
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
LED Headlight rings
Can anyone tell me if there is a specific setting for the headlights to just have the LED rings switched on..? I have a great desk top wallpaper with a 2010 MY car with just LEDs shown as lit but with my DLRs the dip beam light is on and so are the LEDs around the main beam (I think its the main beam anyway)
Wanted to know if I can have DLRs as just the LEDs around both lights on?
Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #319161 23rd Mar 2015 8:50am
IID tool, CCF files> DRL settings > Set to "standard" and they will be on Thumbs Up
Post #319165 23rd Mar 2015 9:02am
comports
Thumbs Up As always Craig - Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #319168 23rd Mar 2015 9:08am
Your welcome Ash Thumbs Up
Post #319170 23rd Mar 2015 9:16am
comports
Hmm. Will have a proper look later on but at first glance i can only see Canadian or Scandinavian DLR enable feature. No standard one to enable (unless it comes with standard turned on by default which can't be disabled? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #319187 23rd Mar 2015 10:29am
Ahh, might only be on my Pro Beta version for now then Ash... Sorry my friend, send GAP a mail and ask them directly sir Thumbs Up
Post #319189 23rd Mar 2015 11:13am
philbathurst
United Kingdom 2016 Range Rover Vogue SE TDV6 Montalcino Red
you need to update your IId tool BT to the latest firmware - then you will see the option for just DRL's as well as the other two options
Post #319192 23rd Mar 2015 11:54am
comports
I already have V3.00 on the IID. I think this is the latest version ?? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #319209 23rd Mar 2015 1:12pm
it does appear to be the latest version.. ... - .- -.
Post #319211 23rd Mar 2015 1:17pm
philbathurst
I updated a couple of weeks ago to V3.19 or something similar, I just connected to the updater to check if I had the latest version and it updated it. the app has been updated by GAP, I then checked the changed screen layout and noticed the other DRL setting in the ccf settings
you could just try connecting to the updater to see if yours has the latest firmware
Post #319240 23rd Mar 2015 4:19pm
