![]() | Home > In Car Electronics (L322) > Reversing camera recommendations... (02-05) |
MattChaloner Member Since: 12 Oct 2014 Location: Corsham, Wiltshire Posts: 52 ![]() ![]() ![]() |
Hi all, looking at fitting a reversing camera to my vogue, have seen the Wiki and have ordered everything I need apart from the camera itself as theres so many different options I've no idea which to get! I'd like to mount it in the stock place under the spoiler if possible, so has anybody done it here that can point me in the direction of the camera they bought? |
I've ordered a loom which plugs into the TV module to allow multiple AV in connections and apparently has a specific input for a reversing camera - not sure how the multiple bit works in terms of switching between them though?
tanertimur Member Since: 17 Sep 2011 Location: London Posts: 90 ![]() ![]() ![]() |
Which ffrr do you have is it the pre touch screen non MOST system. (From what you say im assuming it is).
Its pre touchscreen yes, not sure what MOST is so will assume I don't have it.
Zambezi Member Since: 07 Feb 2015 Location: Bury St Edmunds, Suffolk Posts: 67 ![]() ![]() ![]() |
I am also in the process of fitting a camera to my 2002 FFRR. I have completed all the wiring using 2 relays, both use power from the reversing circuit to switch the relays. One relay switches a permanent live taken from the fuse box on the driver's side of the boot whilst the other relay is used to switch the wire that need to be connected to pole 17 of the blue connector on the TV module, to earth to enable the camera feed to be displayed on the SatNav screen when reverse is selected.
