Home > Wheels & Tyres > snow road capability of RR?
x-box
Hi Chaps,
I just come back from France with my 4.4TDV8 , on my last day I took from Nice to Embrun which involve alps mountain roads, I think Embrun is the lake on the mountain and would like to see it. however, as we just started to see the mountain snow and started to climb, the narrow mountain roads was covered by snow and I can tell that no car has been passed for quite some time as at the beginning of the mountain road, there is a snowdrift on the middle of the road and no tyre marks on it. we climb just for less than 20 minutes the snow on the road get thick, I selected low ratio gear, raise the height, put in snow mode, and the car is spinning!!! I tried in Mud mode, and still spinning! I get out and found the snow was about 20-30 CM height on the road. I did not try again on the side of the narrow road was deep cliff and I certainly don't want it out of control by spinning. I guess if I reverse some distance and try to climb it could pass that section but my girlfriend suggested that snow condtion will be worse as it gets higher and its getting dark, so I took the advice and reverse back......
my RR is on 250 55 R20 scorpion stand tyre, is the spinning normal for this? I guess this tyre doesn't have much grip for 20-30 CM snow? if I change to GG AT tyre, is that going to get any better and ok for this situation? to be honest, I was a bit disappointed by this, as it just stated to climb and failed. maybe because my off road skill not as good.....
any suggestion guys?
Henry
Post #318631 19th Mar 2015 10:59am
Why are you driving in those conditions on summer tyres - never mind without chains?
Post #318634 19th Mar 2015 11:08am
how many mm on your tyres ? ........... snow/winter tyres would have been more appropriate and as would snow chains.. ... - .- -.
Post #318635 19th Mar 2015 11:11am
x-box
there were 6/7mm left on the tyre, initially I didn't intend to drive on those road and didn't expect the road was covered by such thick snow neither, and also I was expecting the RR should be ok for those tarmac road + snow conditions.
winter tyre + snow chain or summer tyre + snow chain?
Post #318636 19th Mar 2015 11:18am
with that amount of mm you should be ok on a flat snow covered surface but certainly not for an incline or hill.... ... - .- -.
Post #318639 19th Mar 2015 11:23am
x-box
should I change to GG AT tyre plus chain?
Post #318640 19th Mar 2015 11:27am
ebajema
I think for these conditions, normal AT tyres are not even enough. You really need proper winter tyres with the specific profile and rubber.
The normal and AT tyres just can't get any grip on the snow and that has nothing to do with the drivetrain, TR etc. It is like ABS, if the tyres are sliding sideways because you're on ice, ABS makes no difference to you sliding of the road.
I bet if you had proper winter tyres, you would not even have needed that TR system much. I drove a XC90 in Sweden in various road conditions with proper studded winter tyres and on every surface I could go like a lunatic almost without ever needing anything like TR or playing with diffs/low range. You can drive a 2wd on snow and ice with proper studded winter tyres, people in the Scandinavian countries do it all the time.
So it is the tyre, not the car IMHO. MY 2010 5.0 SC Galway green and sand interior!!
Post #318643 19th Mar 2015 11:59am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
For winter conditions you need winter tyres, not Grabber ATs (although chunky tyres are good in fresh snow).
Chains on what you have sounds sensible - can't imagine the French police would have been very amenable if you'd got yourself stuck up there without them.
Post #318644 19th Mar 2015 12:00pm
x-box
ic ic tyres are the most critical thing when driving in the snow......
any R20 tyres you guys recommend for this? please......
Post #318647 19th Mar 2015 12:13pm
steptoe
Snow/winter tyres.....
Just because it's a four wheel drive it doesn't give you any more grip in the snow, just more traction.
Which isn't the same as grip.
Post #318648 19th Mar 2015 12:14pm
Dolphinboy
I have driven to the Alps in my old 2002 TD6 and my 2004 V8 and have only ever had M&S tyres on - never had a problem. coped with snow over 30cm deep and got up icy back roads in St Anton. Maybe the electronics were trying to be too clever? (My old girls don't have any of that new-fangled gizmos, just pure British pluck (or stupidity Whistle ??)
Post #318663 19th Mar 2015 1:08pm
It's stupidity. Almost the only cars I see skidding around the ski resorts are British 4x4's on summer tyres.
Post #318664 19th Mar 2015 1:12pm
x-box
any good winter snow tyre you guys recommend for R20 rim?
thanks
Post #318666 19th Mar 2015 1:43pm
x-box, there are some excellent winter tyres in that size, Michelin LATITUDE ALPIN, Pirelli Scorpion Winter, Vredestein WINTRAC XTREME S.
I have 18's so not sure about 20's, but I'm very happy with my Vreds.
Post #318667 19th Mar 2015 2:16pm
x-box
many thanks,
I think I will choose one of them.
regards
Henry
Post #318669 19th Mar 2015 2:33pm
