Home > In Car Electronics (L322) > Android head unit kitkat screen shots & How To Update
hex
United Kingdom 2002 Range Rover HSE Td6 Baltic Blue
few screen shot after the upgrade
of the android OS
instructions on how to upgrade to follow Very Happy
Post #318598 18th Mar 2015 10:18pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
KLF - good choice!! 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #318599 18th Mar 2015 10:30pm
That looks good Paul, will do mine when I get some time....
Keep up the good work.... Pete
Post #318602 18th Mar 2015 11:04pm
Stuntman
United Kingdom 2002 Range Rover HSE Td6 Zambezi Silver
Wtf! Well done, ok I have to ask
How do I get that goodness in my life?
Post #318899 20th Mar 2015 9:26pm
hex
DO NOT ATEMPT TO DO THIS IF YOU ARE UNSURE
all settings, passwords,apps etc will be removed
Do a back up of your internal SD card memory. It will be wiped during the process.
Back up your GPS card .
Get the files
Download files from here http://huifei.fs-fileserver.de/content/firmware/coudu's_roms/4.4.4/800x480/
I am running 27-Jan-2015 11:26 353M KLD version
Other versions here http://huifei.fs-fileserver.de/content/firmware/ don’t use any of the Klyde files as they are not for the units we have
And useful files here
There are 2 kinds of files
- update.img is the android firmware
- mcu.img is the mcu update (don’t use )
Extract the file to a usb stick
Copy the update.img from the usb to the root of your GPS card.
MAKE sure to remove the usb and the other SD card before you restart
Insert back the GPScard to the unit. If no window pops up, reboot the unit. At boot, the presence of update.img will be detected and a pop up window will ask you whether you want to update your unit.
It will automatically reboot into recovery mode and update your unit. Once done, remove update.img root of the gps card or you will be asked every boot for an update.
If anything goes wrong you can revert back during the upgrade
1 Press reset button and power button together
2 After about 5 secs release reset button, but keep pressing power button
3 When booting screen appears release power button.
4 It boots into recovery.
From here you can factory reset , recover or upgrade
When its all back up you can side load the IGO from the GPS card by selecting the igo APK file but have all other SD cards removed and the USB
Post #318961 21st Mar 2015 3:57pm
Stuntman
Hi hex, I may be sounding like an utter bumpy here, by backing the internal sd card, what do you mean?
I've been working for the last 21 days on 12-14hrs a day and my heads a little frazzled!
Post #318989 21st Mar 2015 8:38pm
hex
When you use the file explorer on the head unit you should see the GPS card and an external SD card if you have one .also you will see one just called SD card this is the internal card that you need to back up
Paul
Post #318999 21st Mar 2015 9:34pm
Stuntman
Thanks dude,
I'm off to bed and try thus again tomorrow nigh after work 😌
Post #319000 21st Mar 2015 9:36pm
