Home > Technical (L322) > 'Hack' for TV/DVD on the Move: UPDATED
Page 3 of 3 <123
budha
England 2006 Range Rover Autobiography 4.4 V8 Java Black
I had mine fitted but you will find them at tv-in-motion.co.uk for £199.00. I guess the secret button would be to turn it off if you were stopped??? maybe!!!
Post #51036 20th Feb 2011 5:16pm
Slightly off topic a bit , but tonight while i was sitting in the car park waiting on SWMBO i was Censored arsing about with the touchscreen and managed to find another way into this code thing but the screens that it showed me were totally different from the ones that RRUK has posted .
But weeks back when i did the same thing with the 753 code the screens were the same as RRUK's ......
Useless bit of info tho just thought i would post it ........ Thumbs Up
Post #53991 10th Mar 2011 8:38pm
Porridge
Ireland 2007 Range Rover Vogue TDV8 Java Black
There is a pretty good Denso PDF doc with instructions for accessing "753" mode.
Is there somewhere I can upload it? 836k size.
Post #58061 1st Apr 2011 8:36am
will it go up on the 'wiki' ? ... - .- -.
Post #58063 1st Apr 2011 8:37am
stu
prior to buying the FFRR i had a VW Touareg, i also had the VCDS diagnostic system for my laptop and with that you could change bytes and bits to alter various settings.
is this not what is required to keep the tv on permanently and what diagnostic system would do this on a RR??
anyone expert in these matters? Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #66921 4th Jun 2011 8:57am
stu
have no problems going through the hack process, everything goes to plan, just when i have finished and go to pull off, the screen goes blank with the safety message and only audio available.
what am i doing anything wrong? Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #67901 9th Jun 2011 5:22pm
Perform the hack whilst moving? 2008 MY Supercharged
Post #67902 9th Jun 2011 5:25pm
stu
will give it a go...thanks Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #67903 9th Jun 2011 5:49pm
gl
Sweden 2011 Range Rover Autobiography TDV8 Bournville
does anyone know if this works for the my11? 2011 tdv8 autobiography bournville / Arabic
2012 tdv8 autobiography orkney gray / jet/jet waiting
Post #82335 19th Sep 2011 10:28am
up in wiki.....thanks to porridge for supplying this.. ... - .- -.
Post #82339 19th Sep 2011 10:37am
As an addendum, now that I have a 2010MY car I tried this and although the Sat nav hard buttons have moved sides and changed around, the procedure is exactly the same.
Illustrations:
Go to the Home screen as shown:
Press and hold in the centre for 5 seconds:
Press and hold the Navigation hard button for 5 seconds, and then press "753 and then then OK"
Select Video Inputs Test
Choose the input you want to use (Tv/DVD or Rear camera or companion camera
 Discovery 4 HSE
Post #203743 13th Aug 2013 8:40am
Maxmax171
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Ok i can get to the hidden menu i then put in 753 press ok and get all the other menus, which one do i change to get TV on the go? or is it supposed to work once ive pressed 753 ok. Embarassed
IGNORE MY STUPIDITY!!! Note to self, I should read all pages of wiki by using the little tab on the bottom that takes you to pages 2 and 3!!!
Sorry peeps!
Post #318158 15th Mar 2015 4:49pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Once you've put the 753 code in and pressed OK, the Diagnostic Menu screen will appear.
Press the button that says Video Inputs test,
then press the button that says TV/DVD.
Then you can select which input on the next screen.
If the TV screen is selected and looks wrong (ie the picture is poor) you may need to press the PAL / NTSC button to correct.
The TV/ DVD or rear camera will be on until you turn off the ignition. You would need to redo each time the ignition goes off / on . ie, it will not turn this feature on permanently. You would need a separate module for that.
I understand that it is illegal for the driver to be able to view a TV / DVD screen whilst the vehicle is under their control. GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #318162 15th Mar 2015 5:53pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Would be good if someone made a video and uploaded it to show Whistle _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #318235 16th Mar 2015 8:38am
there's this for the RRS which is the same [i think]
Post #318236 16th Mar 2015 8:40am
Page 3 of 3 <123
