Home > Technical (L322) > 'Hack' for TV/DVD on the Move: UPDATED |
Slightly off topic a bit , but tonight while i was sitting in the car park waiting on SWMBO i was arsing about with the touchscreen and managed to find another way into this code thing but the screens that it showed me were totally different from the ones that RRUK has posted .
10th Mar 2011 8:38pm |
Porridge Member Since: 31 Mar 2011 Location: Dublin Posts: 51 |
There is a pretty good Denso PDF doc with instructions for accessing "753" mode.
1st Apr 2011 8:36am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35248 |
will it go up on the 'wiki' ? ... - .- -.
1st Apr 2011 8:37am |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
prior to buying the FFRR i had a VW Touareg, i also had the VCDS diagnostic system for my laptop and with that you could change bytes and bits to alter various settings.
4th Jun 2011 8:57am |
have no problems going through the hack process, everything goes to plan, just when i have finished and go to pull off, the screen goes blank with the safety message and only audio available.
9th Jun 2011 5:22pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Perform the hack whilst moving? 2008 MY Supercharged
9th Jun 2011 5:25pm |
will give it a go...thanks Current: TDV8 (3.6) RRS HSE
9th Jun 2011 5:49pm |
gl Member Since: 23 Aug 2010 Location: stockholm Posts: 84 |
does anyone know if this works for the my11? 2011 tdv8 autobiography bournville / Arabic
19th Sep 2011 10:28am |
up in wiki.....thanks to porridge for supplying this.. ... - .- -. Y. O. L. O. . |
19th Sep 2011 10:37am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
As an addendum, now that I have a 2010MY car I tried this and although the Sat nav hard buttons have moved sides and changed around, the procedure is exactly the same.
13th Aug 2013 8:40am |
Maxmax171 Member Since: 01 Feb 2015 Location: Devon Posts: 9 |
Ok i can get to the hidden menu i then put in 753 press ok and get all the other menus, which one do i change to get TV on the go? or is it supposed to work once ive pressed 753 ok.
15th Mar 2015 4:49pm |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Once you've put the 753 code in and pressed OK, the Diagnostic Menu screen will appear.
15th Mar 2015 5:53pm |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1199 |
Would be good if someone made a video and uploaded it to show _____________________________________________________
16th Mar 2015 8:38am |
there's this for the RRS which is the same [i think]
16th Mar 2015 8:40am |
