Home > Technical (L322) > AC auxiliary fan not spinning ANY IDEAS?
Starberg
Sweden 2003 Range Rover Vogue 4.4 V8 Java Black
I have noticed a strange "fizz" sound coming from my hevac system every other 20 - 30 seconds or so. It sound like that for 2-3 sec and then its quiet again. I belive it has something to do with the AC. Sounding almost like a relif valve releasing pressure.
I also noticed today that my ac aux fan wasnt spinning so it made me belive it has something to do with it.
Anyone bin having the same problem or got any tips on how to get the fan working again?
Cheers L322 Vogue 2003
Post #318007 14th Mar 2015 2:50pm
Sound maybe the bearing on the compressor, you only hear it when the clutch cuts in and out about the right timings you mention... Mines been noisy for over 15,000 miles, keep meaning to sort it......
The fan only comes on when needed, and it needs to get very hot before it comes on..... Pete
Post #318037 14th Mar 2015 6:47pm
Starberg
Thanks for the help! Smile
Is there a fix for the bearing or do you need to change to a new compressor? L322 Vogue 2003
Post #318146 15th Mar 2015 2:47pm
Pretty sure I read somewhere you can change the front bearing without removing the pump, although I haven't had a look at mine yet, if the pump still works then someone somewhere will be able to change the bearing...
You can confirm the pump noise by taking the drive belt off... is a bit of a job if you've not done it before though, the viscous fan is a bit of a pain... Pete
Post #318151 15th Mar 2015 3:38pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Searched everywhere and it doesn't appear that the bearing / clutch Is available separately. Sad
Maybe contact denso directly, or buy replacement compressor?
Greg
Post #318176 15th Mar 2015 7:06pm
It'll be a standard bearing, just need to get it out and it and measure it....
Going to do mine when the weather gets a bit warmer.... Pete
Post #318186 15th Mar 2015 7:48pm
gregdav
Ahhh the old look up the bearing number. Thumbs Up
gotcha pete. Thumbs Up
how are you going on now pete, is the hip on the mend now?
greg.
Post #318190 15th Mar 2015 8:07pm
Yes thanks Greg, new hip is great, on list for other one now, main problem is knee, now totally gone, won't lock straight, can't bend it past 30degrees... so it totally prevents me from getting my teeth stuck into the bigger Jobs on the FF... so just playing at the moment... got lots of big lumps of steel in the garage awaiting playing!!!! They can't do the knee until after the hip so a few more months to wait... Pete
Post #318203 15th Mar 2015 9:13pm
gregdav
Bl Censored y hell mate your going through the mill, but glad things are going on ok. Ain't funny when you can't get out and about and under the rr. Good luck mate hope you get sorted Thumbs Up
Post #318207 15th Mar 2015 9:34pm
johnboyairey
"Steve Austin, astronaut. A man barely alive." "Gentlemen, we can rebuild him. We have the technology. We have the capability to make the world's first bionic man. Steve Austin will be that man. Better than he was before. Better...stronger...faster."
Pete, soon you will be making those shimmering sound effects, as your new joints, make you stronger, faster, etc Razz
Post #318217 15th Mar 2015 10:27pm
Just back to some sort of normality would do..... Pete
Post #318223 15th Mar 2015 11:04pm
