Home > Technical (L322) > Brakelights/Switch. L332 TD6 |
Where the codes cleared/reset after the new brake light switch was fitted?
9th Mar 2015 6:34pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
I think there may be a big hint in your last post, what year 'upgrade' lights are they, if they're LED light units, then do they possibly not need the extra wiring bits to make them work properly? If that's not been done, then that could be the root cause of the problem.
9th Mar 2015 7:04pm |
Dazzler Member Since: 09 Sep 2013 Location: West Sussex Posts: 34 |
Thankyou will check bulbs yes codes were cleared.
9th Mar 2015 7:36pm |
No worries Dazzler, was just thinking that there was a post in the link mentioning HDC/ABS/Air Susp Inactive warnings coming up if the ballast resistors, extra wiring boxes, etc., weren't fitted. Thought that there might be a fault with a resistor or possibly the wiring which may be the culprit, especially if the lights have been in for 6 years plus. |
9th Mar 2015 8:01pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
what's a LCM, and is it fitted to the 08 tdv8?
10th Mar 2015 10:35am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35336 |
light control module...and yes you do have one. ... - .- -.
10th Mar 2015 10:37am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
We all have one Even Stan |
10th Mar 2015 11:58am |
