Home > Technical (L322) > Brakelights/Switch. L332 TD6
Dazzler
England 2003 Range Rover Vogue Td6 Zambezi Silver
Hi, my Brakelights were staying on and then flashing etc ,mainly on its 1st start up of the day. I changed the pedal switch and it solved the problem cleared the code on the ecu. I then noticed when I turned the ign key onto the 1st position the brakelights flashed on and off once,when turning the key off no flashing is this normal?. The brakeswitch code has also re appeared on the ecu. Could the problem be the Brake Module???.Also the dreaded Air suspention inactive/hdc/abs etc has reappeared,gone into suspention ecu No codes stored. Would this all be linked ????. Kind Regards
Darren
Post #313782 19th Feb 2015 8:18pm
I don't know about your brake switch but the air suspension inactive / hdc / abs lights on usually indicates a low voltage occurrence. Hows your battery?
Post #313812 19th Feb 2015 9:38pm
Brake light faults on the early cars is usually down to a failing LCM... Thumbs Up
Post #313837 19th Feb 2015 10:26pm
DMRR
Have you fitted any LED's to the vehicle? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #313840 19th Feb 2015 10:31pm
Dazzler
Hi thanks for your reply,Yes the rearlights are Led;s
Post #313843 19th Feb 2015 10:36pm
Dazzler
Thanks will check Battery
Post #313847 19th Feb 2015 10:39pm
DMRR
If you have an IID, switch off cold/hot monitoring and it should stop the flash (that's the car checking the lamps if they are filament)
If you don't ... well it's just the check it does and a standard lamp doesn't respond Smile
ECU's rarely fail in such an odd way. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #313848 19th Feb 2015 10:39pm
Dazzler
Cool Thankyou Smile
Post #313849 19th Feb 2015 10:41pm
Yes they do! Very common LCM's failing and leaving the brake lights permanently on!!!
Post #313852 19th Feb 2015 10:55pm
DMRR
Bow down
That's not his current symptom Craig. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #313855 19th Feb 2015 11:04pm
Dazzler
Hi checked multiplugs sensors all ok. went to LR specialist only thing that came up was Brakelight switich. The new one I fitted was from LR Direct a Brtipart switch. Specialist said get a Genuine one and try that. Done this today and the brakelights stayed on permanently ?? Sad . Put Britpart one back on all fine again.ABS lights hdc/air suspention stayed on with both switches. Could it be the Light Check Module ?. If so where is it Located please. Thankyou Darren.
Post #315039 26th Feb 2015 9:28pm
Behind the bonnet pull panel... Black box Thumbs Up
Post #315040 26th Feb 2015 9:37pm
Dazzler
Cool thankyou. Hope this is what it is. Coz Im pulling my Hair out Sad
Post #315041 26th Feb 2015 9:43pm
Dazzler
Evening well Changed LCM fitted new genuine brakelight switch cleared the codes. Hey Presto Thumbs Up Air Sus/HDC/ABS All went away. Brakelights working fine. Drove 150 miles all good. Drove 3 miles today to my Shock Shocked All back and the Brakelight on permanently Big Cry Big Cry , Any Ideas please.
Post #316223 4th Mar 2015 8:47pm
Somewhere in my memory bank i remember there being an issue with a loom between the abs ecu and either the lcm or the bcm and JLR suggest you cut a wire from the abs ecu...
Ill do some searching tomorrow for you fella... Thumbs Up
Post #316250 4th Mar 2015 11:18pm
