Home > Maintenance & Mods (L322) > Interior courtesy lights won't turn off!
mercuryf1
Malaysia 2015 Range Rover SVAutobiography 5.0 SC V8 Loire Blue
I had the interior roof lining replaced in the car. When the car came back, the courtesy lights started to play up. When I lock the doors with the remote, the lights start to dim but immediately powers back on! Usually the lights will just fade away.
I asked the fella that did my roof lining what could be the problem? He said the front courtesy lights are simply removed with a clip and there is no way that he couldn't have reassembled it wrong. "cos the clips only clip in one direction.Similarly with the Courtesy lights in the centre of the car, the detachment and subsequent reinstall was pretty straight forward job too!
Now I cannot turn off the interior lights at all This will run the battery to the ground empty!
Any ideas for a solution?
thanks '01 1.8i Freelander. Grey/ grey
'06 4.2 S/C Buckingham Blue/ Parchment
'15 5.0 S/C SVA Loire blue/ Black
Post #316960 8th Mar 2015 7:23pm
I don't know if this is a solution to your problem but the first thing I would do is disconnect the battery for 20 minutes then reconnect it and see what happens.
You might be lucky.
After reconnecting the battery don't forget to start the engine and turn the steering wheel fully lock to lock to reset the steering sensor.
Post #317003 8th Mar 2015 9:31pm
mjdronfield
I understand that holding the switch in turns them off, and again for manual on.
Not tried it myself.
Might help whilst you get the problem fixed.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #317036 8th Mar 2015 11:38pm
I think what he had done is put your rear light in the front & visa versa... Although both interior lights appear to be identical they are NOT sir... The circuit boards have different hardware/software so behave differently if accidentally plugged back in the wrong way around...
Ill keep my fingers crossed for you Thumbs Up Whistle Thumbs Up
Post #317051 9th Mar 2015 7:40am
havnt the front and back interior lights have different plugs? ... - .- -.
Post #317068 9th Mar 2015 9:19am
mercuryf1
Absolutely SPOT ON! swapped the units around, re-set the battery and all systems back to normal! phew!
Thanks for that amazing tip Craig! You are a champion!
Thumbs Up '01 1.8i Freelander. Grey/ grey
Post #317108 9th Mar 2015 1:47pm
Cheques made payable to ....................
Laughing Laughing Laughing Thumbs Up
Glad i could help sir Thumbs Up
Post #317109 9th Mar 2015 1:50pm
mercuryf1
LR should have made different plugs for the front and rear but the plugs are identical - just different colour.
One is white, the other black! Rolling Eyes '01 1.8i Freelander. Grey/ grey
Post #317110 9th Mar 2015 1:50pm
mercuryf1
Amazing! Many thanks again from a different time zone and many thousand miles away!
Post #317111 9th Mar 2015 1:53pm
Your very welcome sir Bow down Thumbs Up
Post #317113 9th Mar 2015 1:58pm
CEEGEE
If it weren't for this forum and the great contributors who help resolve many of the problems, I wouldn't contemplate running a RR out of manufacturers warranty Bow down Thumbs Up Bow down Thumbs Up Bow down Thumbs Up
Post #317115 9th Mar 2015 2:04pm
Post #317156 9th Mar 2015 7:41pm
