![]() | Home > Technical (L322) > Unexplained battery discharge???? |
Full fat not diet Member Since: 16 Nov 2008 Location: Herts Posts: 1209 ![]() ![]() ![]() |
i take it they checked for any battery drains? |
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
Mine got a drain dealer cant trace why I'll live with it gonna fit a aux battery for the Winch |
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 254 ![]() ![]() |
I guess they checked for drains. They said they'd given it a complete once-over. The ideal solution would be an auxiliary battery. Unfortunately, the LPG kit is where they'd fit it. Is there anything which typically causes a drain? The RAC bloke said a drain could even be something as simple as a lightbulb! |
Sat Nav /tv and Tracker are two i have had |
Good try. It's an HSE and doesn't have either. |
Transport fuse 14 but I guess as its a 2003 theres no danger of that
Oh where have they fitted the LPG bits to get in the way. I'm thinking of the towball storeage area |
You're probably right about the battery. If it wasn't stuffed before, it probably will be now. Good point about the LPG kit. I was thinking the battery would go in the spare wheel well somewhere so that may be an option now. Any more thoughts? |
jonny142 Member Since: 29 Oct 2008 Location: Sheffield Posts: 28 ![]() ![]() ![]() |
[quote="JW911"]You're probably right about the battery. If it wasn't stuffed before, it probably will be now. Good point about the LPG kit. I was thinking the battery would go in the spare wheel well somewhere so that may be an option now. Any more thoughts?
Browsing and came across this
Thanks, Jonny. Sounds like the problem. Will mention the HVAC and TSB to my specialist as well. |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
started having the odd battery issue, always when i least needed it. Pre heater seemed to kill it off
New battery installed on Tuesday after minor gearbox issue (wouldn't change up beyond 2nd in auto - ok in manual). Everything now back to normal or so it would appear. If certain computers aren't getting enough voltage, they reset which can cause a few issues. Watch this space.... |
Just left it parked up for three days and it started first time with no problem whatsoever. Guessing the battery was mullered. |
