Home > Maintenance & Mods (L322) > Front Towing Eye
devonchilliman
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Front Towing Eye
Gents I need your help please Bow down
I want to permantly expose my front towing eye on the FF,on my previous D3 & D4 I've removed the plastic cover and fitted a Mantec Sumpguard like the one below...
Is there such a thing available for a FF and if so I'd be very greatful for any links Bow down
TIA
Post #315990 3rd Mar 2015 6:42pm
Yes & no Rolling Eyes
G4 (mantec) under body protection was made for the 02-06 & for the 06-09 but to my knowledge never made for the 09> cars as the G4 challenge was discontinued Rolling Eyes
I have both here if your passing and want to look? I would think the 02-06 would maybe fit the later cars???
Post #316003 3rd Mar 2015 7:16pm
devonchilliman
What is it with me always wanting the not so readily available Whistle Big Cry ...
Not sure when I will be passing Craig Laughing ...but I need to Thumbs Up ..thanks Bow down
Post #316017 3rd Mar 2015 8:39pm
Thumbs Up Thumbs Up Thumbs Up
Post #316025 3rd Mar 2015 9:05pm
sako243
If you're interested I'm currently chatting with a local (to my parents in West Wales) fabricator to build up some underbody protection for my 2007 TDV8. He's currently having a look at pricing up different kinds of alloys vs. galvanised steel etc.
Someone on this forum did manage to persuade Mantec to do a limited run of their G4 stuff but we weren't sure whether it would fit a TDV8. It was also a pretty penny and probably overkill for what I wanted - just a little extra protection.
[edit]Benefit of going this route is that it'll be completely bespoke so can be customised to what you want.[/edit] Ed
Post #316065 4th Mar 2015 7:55am
devonchilliman
Yes please sako243 Bow down
Mine is a 2011 Thumbs Up
Post #316066 4th Mar 2015 7:57am
sako243
Well I'm hoping to at some point today go under mine in the barn pit to get some dimensions for him. Although I have to take the pack (four labs) out for a walk / shoot first and then replace a fence.
What kind of stuff are you after? The Mantec ones are 8mm and overkill for what I wanted - given most of the time the vehicle's on the road I was looking along the lines of 3mm ish to cut down on weight but still offer protection against the more "violent" gentle knocks. Ed
Post #316069 4th Mar 2015 8:05am
devonchilliman
Ed...
I'm not going to be seriously off roading,but I do a lot of work on farms and occasionally I need to be recovered by a tractor Embarassed,there's nothing worse than getting stuck and then having to lay down in the mud to remove the stupid plastic cover,but with this removed the front end looks awful,so it's primarily to make the front more acceptable Thumbs Up
Post #316072 4th Mar 2015 8:11am
sako243
Similar usage to me then - except I'm aiming to take mine to Morocco at the end of the year. Although I was primarily focused on the underbody protection rather than front-end but I'm sure Chris can work around it. Ed
Post #316073 4th Mar 2015 8:17am
can you not fettle away a bit of the plastic to make the 'ring' more accessible.. ... - .- -.
Post #316074 4th Mar 2015 8:19am
devonchilliman
Morocco ...wow !
I've contacted Ray(RLD) on the D4 forum as his work is legendary,but unfortunately he can't help Big Cry
Post #316075 4th Mar 2015 8:20am
devonchilliman
Stan that's plan B Thumbs Up
Post #316076 4th Mar 2015 8:20am
could you maybe fettle it enough to be able to clip one of these on the tow eye,
http://www.ebay.co.uk/itm/RED-Winch-Brothe...3a92b20da2 ... - .- -.
Post #316081 4th Mar 2015 8:37am
devonchilliman
Thanks ,I was going to say is that man enough then noticed 4000kg Thumbs Up
Post #316082 4th Mar 2015 8:44am
This is the Mantec one,
It is very substantial and well over the top for normal laning and off roading, it's only touched a few times, I would have thought 4mm would be strong enough for most...
The fuel tank is actually the lowest thing under there, I'd be tempted to get that sorted as well, mines got the Mantec guard on there and it's hit more, also the transfer box cage will get caught, I used the rear exhaust guard (modified) to fit that and it's had some use!! Never hit the exhaust though!!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #316083 4th Mar 2015 9:01am
