![]() | Home > Maintenance & Mods (L322) > Rear washer leak repair - the cheaper option! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
thats cheap, good find sir,
Y. O. L. O. . |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6768 ![]() ![]() ![]() |
No |
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
Ok - do it once etc. I just didn't want to find out something else perishes a few months down the line and have to take it all off again.
If it ain't broke............... |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
I have a new motor/pump unit and a new wiper arm and jets but the water still takes ages to start and then is more of a flow than a spray. Can someone please advise (with pics if possible) where to try and insert a non return valve if this is likely to solve the problem. There is a difference between knowing your sh!t and knowing you're sh!t
Not sure on this non-return valve but even on my rear washer (albeit leaking at the moment), it flows out - doesn't spray, mine is not new, it's the original. |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 ![]() ![]() |
I did alanm_3�s �cheaper� rear washer leak repair today and I shall be eternally grateful to him for having devised this clever mod. Even taking things very, very slowly and carefully, and losing a lot of time searching in my various boxes for suitable screws, I had the whole thing done in about an hour and a half.
Appreciate your kind comments. Glad it did the trick for you |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
+1 of thanks - top drawer, �5.00 delivered to the door. Nice easy fix and working perfectly now |
I have yet to do mine but this is encouraging. I think I am most worried about getting the trim off and not snapping anything. |
I was too, so I understand your concern.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Yep, think mine has a couple left now! Still holds on fine though! There is nothing that can't be fixed with a hammer😜😜
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 114 ![]() ![]() ![]() |
Thanks for this tip. Guess what I'm going to be doing in the near future! Car history includes: LR Series 3, RR Classic x 4, LR 101, Discovery 1 and 2 and now FFRR.
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 ![]() ![]() ![]() |
Tried this on mine .but still leaks |
