cheers, there are britpart hubs available for about £50, I'm a little dubious about quality though, however i would doubt that they would make these and they are probably OEM via britpart......
good call on the bearing
My NSF hub may be a bit knackerd, I noted that someone has mullered the centre flange, i suspect it was the dealers when they changed the driveshaft gaiter last year. the centre has been knocked out of shape slightly which means the wheel is really tight over the centre of the hub. I wonder if it has knocked the hob out of shape There is nothing that can't be fixed with a hammer😜😜
