Home > Technical (L322) > brake judder or something else?
Mikey
I have had a brake wobble with 3 sets of discs too. Just trying to find enough spare time to replace both front hubs Big Cry
Post #315475 28th Feb 2015 8:41pm
Out of interest how much was the new hub fitted? There is nothing that can't be fixed with a hammer😜😜
Post #315506 1st Mar 2015 9:08am
rover1
northernmonkeyjones,
Luckily for me there was new flange on ebay surplus to requirements.
I paid £42 posted and bought a new wheel bearing for £26 from a local supplier.
The garage had a nightmare getting the old hub off and i had some other small jobs done so to be honest i cant give you an accurate cost but i'm thinking 2/3 hrs labour (£80 to £120) + the £68 for parts.
I believe the flange new is around £85 + Bearing.
Sorry this is a bit vague.
Ian
Post #315521 1st Mar 2015 10:03am
cheers, there are britpart hubs available for about £50, I'm a little dubious about quality though, however i would doubt that they would make these and they are probably OEM via britpart......
good call on the bearing Thumbs Up
My NSF hub may be a bit knackerd, I noted that someone has mullered the centre flange, i suspect it was the dealers when they changed the driveshaft gaiter last year. the centre has been knocked out of shape slightly which means the wheel is really tight over the centre of the hub. I wonder if it has knocked the hob out of shape Rolling Eyes There is nothing that can't be fixed with a hammer😜😜
Post #315546 1st Mar 2015 11:22am
