Home > LPG > LPG problem, advice appreciated
Knightrider
Hi the LPG on my car has developed a problem whereby it won't switch over to gas anymore and just beeps until I select petrol which it runs on fine. On a cold start the LPG gauge shows full tank and the LPG light flashing but once the engine warms and the car should switch to gas it just beeps and won't go on gas.
I have a 2 year old Romano premium system which had a new gas filter 2 days before this fault. I've not had a single problem with the LPG in the 12 months prior since I purchased the car.
Any ideas on what could be causing this fault? 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast
Post #314694 25th Feb 2015 1:04am
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
The solenoid valve at the vaporiser will likely be gummed up and stuck - it get's sticky with the LPG residue and needs cleaned.
Happened to mine before - fairly easy fix. Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #314712 25th Feb 2015 7:46am
They have a computer control for them, if you can't find the fault then get it code read by an LPG installer, should tell you whats wrong... also, check you didn't disturb anything when changing the filter... Pete
Post #314718 25th Feb 2015 8:39am
Knightrider
I was thinking to try disconnecting the battery for 30 mins or so to reset the ecu - is this worth a try or will it wipe all the settings off the LPG ecu and cause more potential problems? 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast
Post #314783 25th Feb 2015 3:16pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
should be a fuse for the LPG system just pull that for a reset
this will also wipe the fault code on the LPG ecu (if you intend to get it read)
Post #314797 25th Feb 2015 4:10pm
You can't wipe the LPG ECU by disconnecting the battery...
You can buy a lead and the software for your system, usually some on ebay or try http://www.tinleytech.co.uk/ Pete
Post #314819 25th Feb 2015 6:46pm
Knightrider
Thanks for the advice, I tried the battery disconnection anyway buy the fault is still there, I will take the car to a LPG specialist on Saturday to hopefully resolve the issue, will update you guys once done. 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast
Post #314883 25th Feb 2015 10:02pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Have you checked your coolant level ? If t's low then the vaporiser will not get warm enough to unfreeze the gas .
Post #315014 26th Feb 2015 6:49pm
Knightrider
Hi yes that was one of the first things I checked, coolant level was fine. I'm taking the car in to Save LPG in birmingham tommorow to hopefully get to the bottom of this. 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast
Post #315330 27th Feb 2015 9:51pm
Knightrider
Hi quick update took the car to Save LPG Ltd in Birmingham today, the fault code was showing as no pressure and it turned out to be a blocked valve at the back near the tank. Good call CG-SC you were right but it wasn't the valve near the vaporiser. The valve was removed and replaced with one that is thinner and less likely to get blocked with 'dirty' gas.
Cheap straightforward fix in the end, recommend Save LPG guys to anyone in the midlands they know their stuff and offer good value service. 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast
Post #315473 28th Feb 2015 8:10pm
CG-SC
Glad you got it fixed, I was fairly sure from your symptoms that it would be a stuck solenoid - it is usuallt the one at the vaporiser that gives issues - if it happens again I'd look there......fingers crossed all will be gine though Thumbs Up Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #315976 3rd Mar 2015 5:46pm
