Home > Technical (L322) > Dreaded Flat Battery |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
I think there's a good chance you may have found the problem. |
15th Feb 2015 5:42pm |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
Same happened to my 12S. Wondered why the fuse kept blowing? Fitted new one (from Halfords) & changed over cover to keep LR logo (PITA). Previous cars:
16th Feb 2015 7:00am |
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 |
Well, went to come home from work and the thing won't start again. I even tried the booster they use for vans and while it did try there wasn't enough to start. The volt meter went down to 10. Something then back up in the 11's
20th Feb 2015 6:35pm |
Well I left it overnight then got the jump leads on it. At first it wouldn't start though the voltmeter was reading 13.5v but after a couple of minutes it fired up.
21st Feb 2015 8:32pm |
Iirc the boot wiring wouldn't be up to the job to provide cranking power for the starter.
21st Feb 2015 9:03pm |
Testing CCA isn't always a reliable test from what I can see unless you repeat the test a lot of times to get a good average or just fully change it off the vehicle and compare to another one that's brand new...
21st Feb 2015 9:59pm |
Do you have a voltmeter you could connect permanently inside the car so you could check the voltage whilst you are driving? |
22nd Feb 2015 10:05am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8529 |
Can do that via the hidden menu on the sat Nav screen
22nd Feb 2015 10:15am |
Well there you go You should be able to monitor the alternator output as you drive. If it's consistently above 14.0V it's not your problem. |
22nd Feb 2015 10:20am |
Mine goes high as it puts the voltage back used to start the car, then settles around 13.5-14v the built in volt meter only steps in .5v so I'm assuming that's 13.8v which is bang on. There is nothing that can't be fixed with a hammer😜😜
22nd Feb 2015 10:40am |
Given the inbuilt voltmeter reads on 0.5V steps I'd be inclined initially to use a possibly more accurate voltmeter initially.
22nd Feb 2015 10:57am |
I have one of those that plugs into the 12v socket that someone here recommended. All readings are as expected. I now have it plugged in the boot socket with the display on the parcel shelf so I can see it without opening the car.
22nd Feb 2015 12:25pm |
In my experience the only good cars to jump off are 2.0diesels as I've tried before with a 1.6 golf and it took a few minutes more to get enough juice in compared to a 2.0 gtd and some 2.0 Citroens I've had around FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
22nd Feb 2015 12:39pm |
12.2V is low if it stood all night prior to starting.
22nd Feb 2015 12:44pm |
