Home > Technical (L322) > Dreaded Flat Battery
Page 5 of 7 <1234567>
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
The battery always seems to settle at 12.2v. Could that be the battery that is faulty then.. I've just had it out and it started 3 times no problem.
Post #314352 22nd Feb 2015 4:59pm
The battery reading is definitely low especially as you are using the car. On a decent barrery the voltage should be 12.6V minimum. Your car will start quite happily with 12.2V but I certainly wouldn't rely on it.
It's difficult to know what to suggest as it may cost you money un-necessarily but your battery does appear a bit suspect particularly given your car was fitted with a new alternator not so long ago.
I have a spare 110AH battery you can borrow if you fancy a 120mile drive. Thumbs Up
Post #314355 22nd Feb 2015 5:16pm
Fish
Thanks, it's looking more and more likely that a new battery is needed even though this one is less than 12 months old. Before I bought it Geoff had done the alternator, fsr etc.etc.
Post #314357 22nd Feb 2015 5:28pm
Did you replace the battery when you replaced the alternator? If the Alternator was spiking then it could have knackered the battery in which case it won't hold charge properly.
My 90Ah was duff after the alternator went! There is nothing that can't be fixed with a hammer😜😜
Post #314358 22nd Feb 2015 5:42pm
Fish
I think everything was done at the same time while he was trying to sort the flat battery problem.
I've put it on a recon charge again and will se how it goes.
Post #314361 22nd Feb 2015 5:52pm
Fish
I ran the recon cycle overnight and when I checked it this morning while still connected it was showing 13.5v. When I unlocked that dropped to 12.2v.
I drove to work (3 miles) and parked up then checked it once everything had time to shut down and it's now showing 12.6v.
I'll keep my eye on it again over the next few days and see if it starts dropping to 12.2v again.
Just checked again around 1.30pm and it's still 12.6v.
In the meantime I've ordered the towing socket adaptor from the D3 forum and some heavy duty jump leads.
Day 2 - 12.3v this morning
Day 2 - 12.2v this evening. Showing 14.8v when running and 12.5v after a short run home.
Day 3 - 12.3v this morning
Day 4 - 12.2v this morning
Day 5 - 12.3v this morning after a good hours run each way on the motorway yesterday Confused
Day 6 - 12.1v this morning
Post #314454 23rd Feb 2015 10:19am
Fish
Based on the readings above I have either got a drain or the battery can't hold full power Big Cry
I'm not sure which way to go now but I suppose a new battery is easiest.
Post #315413 28th Feb 2015 11:59am
bebechoon
France
Fish: Did you get a new battery in the end, and if so did it cure your problems?
I have a similar sort of story. Although I haven�t in the past had any problems, after recently flattening the battery using the IID tool Big Cry and fully re-charging it, I�ve been nervous and checking regularly since Shocked . Although showing a healthy 13-14V with the engine running Thumbs Up , it shows only around 12.2V after having been left overnight.
The battery�s just under 2 years old (guaranteed for 5, so I�m not too worried �), but I just wondered if I have a problem or not �
So, what�s your experience, please? Any other comments from this learned community would also be gratefully received! It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 7 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #316537 6th Mar 2015 12:28pm
those voltage figures sound ok Steve.. ... - .- -.
Post #316538 6th Mar 2015 12:30pm
bebechoon
France
Thanks, Stan. Bow down
I'm relieved to know that. I've been fretting unnecessarily, then! Mr. Green It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
Previous:
Disco II
Post #316547 6th Mar 2015 12:43pm
Fish
I've not sorted mine yet, I've been monitoring it this week. After a few days of short journeys it seemed to settle at 12.2v but this morning was actually 12.1v. I have had a good motorway run today so will check it again tomorrow.
I'm not sure if the problem with the towing electrics has damaged anything else but as it has all the harness has been replaced I'm not sure how. it is due MOT and service so am going to get it checked again while it's in.
The more it goes on the more I am inclined to think it is a battery problem made worse by short journeys. I was doing more mileage when i first got it and the weather was not as bad so no lights and heaters on all the time.
Post #316565 6th Mar 2015 3:31pm
If you've had a decent run on the motorway today your battery should now be reading 12.8-12.9V or even 13V due to surface charge.
This voltage should then decay over a couple of days and settle at 12.6-12.7V depending how long you leave it after that.
I would expect after a week for the voltage to be in the order of 12.6V, anything less means you still have a problem unfortunately.
12.1-12.2V indicates a a battery charged to about half capacity.
Have you actually checked for battery drain by inserting an ammeter in the battery -ve cable?
Post #316593 6th Mar 2015 5:57pm
bebechoon
France
Thanks, nicedayforit (that�s a mouthful! (And do you really look like your Avatar?!!!)
No, I�ve not checked for battery drain. Inserting an ammeter in the battery �ve cable � oh dear! I�ll have to Google that to find out:
a) How to do it
b) What values to expect � otherwise there�s no point
So now you�ve got me fretting again!
Thanks anyway � I appreciate it. Yes, really! (For example, I have values to expect now) It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
Previous:
Disco II
Post #316599 6th Mar 2015 6:26pm
bebechoon
France
Oh, sorry, that last remark by nicedayforit was maybe directed at Fish?
Never mind, it still helps me too It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
Previous:
Disco II
Post #316601 6th Mar 2015 6:27pm
@bebechoon Thumbs Up
If you wish to insert an ammeter into the -ve battery cable, disconnect the cable from the battery, connect one lead of the ammeter to the battery -ve terminal and the other ammeter lead to the end of the disconnected battery -ve cable.
Do this after letting your car go to sleep.
You need an ammeter with a range upto 10A initially, once you have read the current drain, if any, you should then be able to reduce the ammeter scale to 1A or even less.
If your ammeter displays a current of more the 50mA you have a problem.
Ideally the current drain should be no more than about 25-30mA.
Post #316606 6th Mar 2015 6:45pm
