Home > Maintenance & Mods (L322) > 4.2SC - New Oil Filter Housing Assembly needed. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35476 |
makes sense now ryan, it does look like a very fiddly job though.. ... - .- -.
15th Feb 2015 5:42pm |
I think the part leaking and which the new figure 8 O-ring gasket seal is for is called the Oil Filter Housing.
16th Feb 2015 9:54am |
This is an LR warrantied repair.
17th Feb 2015 9:52am |
ryan@ landrover relations might be able to help.. ... - .- -.
17th Feb 2015 10:20am |
Cheers Stan. Seems little point. If I persist with the garage they will book it in.
17th Feb 2015 10:43am |
that makes sense, hope your new chap sorts it for you.. ... - .- -.
17th Feb 2015 10:46am |
If a new LR part/ figure of 8 oil filter gasket seal was fitted then oil still weeping from the figure 8 component mating face, what could be the issue?
21st Feb 2015 8:18pm |
I can think of several potential problems :
22nd Feb 2015 2:33am |
Thanks Eugene,
22nd Feb 2015 8:38am |
No worries mate. Without seeing the actual part up close it is the best I can do, just based on years of tinkering with cars, hydraulics and the likes.
22nd Feb 2015 8:51am |
Based on some online research it seems the oil filter housing can be a common oil leak component on the RR?
23rd Feb 2015 10:52pm |
was the oil seal put in upside down perhaps? ... - .- -.
24th Feb 2015 8:07am |
Worth checking Stan, thanks |
24th Feb 2015 8:08pm |
Well, had good look at this problem now.
7th Mar 2015 7:40am |
