Home > General > Overfinch L322 - what's this then?
Trommel wrote:
You could buy a custom billet crank for less than £5k. Not sure what you could actually do to it to make it that price, apart from mount jewels on it.
Edit - I will qualify it by saying you're obviously risking things not being easily sortable with something like that.
Yes, good alternative. Go and have a bespoke crank machined instead, you'll save thousands. Rolling Eyes
Post #313909 20th Feb 2015 12:03pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Not sure what you are getting at - Craig says the crank is over £5k, I say you could buy a custom billet BMW V8 crank for less.
What point are you trying to make?
Post #313911 20th Feb 2015 12:10pm
I'm suggesting that when Craig pointed out you were wrong, rather than admit defeat you pick some other way of trying to be right.
But you're still wrong!
Post #313912 20th Feb 2015 12:17pm
Philip
I see, just being chippy then.
Aside from that, I always wondered why they went to so much trouble for the results with the 580S (building a new engine, changing gear ratios etc.) instead of, say, supercharging it.
Post #313914 20th Feb 2015 12:34pm
DavidL
It seems to be the OF way - no replacement for displacement.
ETA why can't you quote the previous post?
Post #313917 20th Feb 2015 12:58pm
Philip
No idea!
Post #313918 20th Feb 2015 1:00pm
DavidL wrote:
It seems the last of a breed - reworked engines by OF. And it does look smart.
What has been a bit fragile Craig?
The crank i believe... Rolling Eyes
Post #313921 20th Feb 2015 1:29pm
http://www.fullfatrr.com/forum/topic7927.html
Post #313927 20th Feb 2015 1:48pm
Philip
Craig - do you know what sort of problems?
Post #313930 20th Feb 2015 1:54pm
No, i don't know of anyone fixing them! Its been end of life for the two most recent OF's I've been offered... Many we get offered are back to a standard 4.4 engine as the OF lump has failed in the past...
Every one that i have heard of failing has been crank related but I'm unsure why...
Post #313937 20th Feb 2015 2:31pm
DavidL
Thanks Mr Verbose. I'm not sure it makes reading a thread at a later date as straightforward as it might be but sometimes that's just how it is I appreciate.
Craig - thanks. Shame the expensive trick part also fails. That one appears to have the correct engine (well the covers anyway) but maybe one to miss. Shame. I wonder what a warranty co would say.....
Post #313939 20th Feb 2015 2:42pm
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
That front bumper add on is hideous Shocked
Post #314167 21st Feb 2015 6:23pm
DavidL
Its ok from the front. There are a few odd camera angles in those pics.
Post #314181 21st Feb 2015 7:55pm
