![]() | Home > General > Overfinch L322 - what's this then? |
DavidL Member Since: 14 Nov 2013 Location: wiltshire Posts: 141 ![]() ![]() |
http://www.pistonheads.com/classifieds/use...hp/3713058
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
See here
Did he call my car FAT!!!?!?!?! |
Thanks. Not sure how it ended up here. Could it be moved to the general forum please.
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 ![]() ![]() ![]() |
Hmmm quite like that....5 ltrs...and on cheap tax been an 03 not the stupidly post 06 tax. If it dont work.......burn it!
I had a pre-stupid tax 4.2SC .... they are out there |
But what would you take the 580 S or the 4.2 SC |
4.2SC - more horses and better 0-60 ... oh and it's factory |
The 4.2 Mick... The OF 500 has proved quite delicate with age |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2592 ![]() ![]() |
Just a BMW S62 crank, nothing special. |
Ahem... NO sir it certainly was NOT... Overfinch took an Ascari (S62) Crank and further enhanced it so NO NOT a standard S62 crank at all! |
Good as I was quite tempted! I like things a bit different and I can't afford a softdash LSE 570. Clarkson mentioned a trick crank in the video so it must be true! |
You could buy a custom billet crank for less than £5k. Not sure what you could actually do to it to make it that price, apart from mount jewels on it. Edit - I will qualify it by saying you're obviously risking things not being easily sortable with something like that. |
It seems the last of a breed - reworked engines by OF. And it does look smart.
