![]() | Home > Maintenance & Mods (L322) > Rear squeak |
Paul,
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7894 ![]() ![]() ![]() |
Mine does this from time to time.
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Thanks chaps.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
Knew if I waited long enough for the rains to come my LHR squeak would go away. It has |
Madyaker Member Since: 13 Apr 2015 Location: Wigan Posts: 39 ![]() ![]() ![]() |
I had all the rear bushes replaced to solve this problem. It worked for going over bumps and potholes but I'm currently saving to sort out another squeak on the rear bearings ! |
Rear rose bushes were the cause of my rear end squeak, new bushes and it's never squeaked since |
drive2tractors Member Since: 05 Jul 2015 Location: Kent Posts: 18 ![]() ![]() |
I had an annoying squeak too, (2003 4.4V8), tracked it down eventually to the handbrake cable rubbing through the rubber grommet in the retaining loop bolted to the wishbone. The cable was worn through to the metal sleeve. I rotated the grommet 180 degrees and then slipped some hard plastic tubing over the worn cable. I used 10mm ID air line as hard tubing, 10 cm length split lengthways. I held all in place with a small cable tie butted up to the pipe each end.
Ianmaney Member Since: 27 Nov 2012 Location: Birmingham UK Posts: 118 ![]() ![]() ![]() |
Mine sounded like an old pram up until last Tuesday, had both top hub bushes changed, silence ever since, £160 all in |
