Home > In Car Electronics (L322) > Cubby box 12v socket |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35419 |
you cant make it permanent unless you re-wire it....the boot one is permanent live and you could run a feed to the front.. ... - .- -.
15th Feb 2015 7:14pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
The 12v sockets run through relays, that's why they normally only become live when the ignition is on.
15th Feb 2015 7:16pm |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 |
Thanks for the swift replies guys. I'll have a think about running a feed from the boot socket to the cubby box one. Travelling around in circles again. |
15th Feb 2015 7:20pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
It's a lot easier to do what Discotigger suggests than running a new cable.
15th Feb 2015 7:34pm |
Exactly nicedayforit
15th Feb 2015 7:46pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7830 |
My cubby box one is always live. Must have changed on the later cars......
15th Feb 2015 7:49pm |
^ The wiring diagrams show two options, ignition controlled and not.
15th Feb 2015 8:03pm |
The easy way to find out is to look at the relay panel in the rear right hand cubby box. If there is a relay missing from the board and a metal bridge strap in its place, then the 12v accessory sockets will be permanently live. |
15th Feb 2015 8:15pm |
I think the 100mm of cable as suggested by nicedayforit is the way to go. Ta Travelling around in circles again. |
15th Feb 2015 8:41pm |
Just a point about the cable, as the circuit is fused at 20A the cable also needs to be rated at 20A.
15th Feb 2015 8:48pm |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
My 03 TD6 was always live, this 06 SC is not. It seems that it changed when it went from BMW to Ford under the skin.... 2006 4.2 SC
15th Feb 2015 9:26pm |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
Any pics of the relay you need to bypass? _____________________________________________________
16th Mar 2015 10:44am |
