![]() | Home > Technical (L322) > Slight hunting at 30mph by 100-200rpm.. (new vid page 2) |
Might be worth checking for a binding handbrake.... Land Rover Addict
red_slr Member Since: 06 Oct 2010 Location: Manchester Posts: 42 ![]() ![]() ![]() |
Back wheels off and take the adjuster back a few clicks? Or is it best to take the disc off and have a look? |
DeltaC Member Since: 22 Mar 2010 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
Warped disc?
Ah, well as the OS brake caliper has been stuck on then I guess that could have warped the disc..
Well just been for a drive, the car was fine for the first 5-10 mins. After a few reasonable speed stops I started to get quite a bad judder (in the whole car) and then it started to "hunt" the revs.
Also, just to clarify what its doing.
switch off everything when you take it out next, to rule out aux driven things (i.e. a/c compressor etc) Land Rover Addict
I will give that a go thanks. |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Also check the air suspension compressor/ suspension units - you may have an air leak that is causing that compressor to cut in a lot. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
Fairly sure its not the compressor but will check. Seems work fine (touch wood).
Tried a quick drive with the AC off, still did it.
Here is the video
I have spent all afternoon looking on the internet about this issue.
Could it be a faulty MAF or a fault in the wiring to the MAF? |
