Home > Technical (L322) > Slight hunting at 30mph by 100-200rpm.. (new vid page 2) |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Might be worth checking for a binding handbrake.... Land Rover Addict
8th Oct 2010 9:11pm |
red_slr Member Since: 06 Oct 2010 Location: Manchester Posts: 42 |
Back wheels off and take the adjuster back a few clicks? Or is it best to take the disc off and have a look? |
9th Oct 2010 6:50am |
DeltaC Member Since: 22 Mar 2010 Location: Aberdeenshire Posts: 148 |
Warped disc?
9th Oct 2010 8:01am |
Ah, well as the OS brake caliper has been stuck on then I guess that could have warped the disc..
9th Oct 2010 8:26am |
Well just been for a drive, the car was fine for the first 5-10 mins. After a few reasonable speed stops I started to get quite a bad judder (in the whole car) and then it started to "hunt" the revs.
9th Oct 2010 9:45am |
Also, just to clarify what its doing.
9th Oct 2010 9:49am |
switch off everything when you take it out next, to rule out aux driven things (i.e. a/c compressor etc) Land Rover Addict
9th Oct 2010 11:19am |
I will give that a go thanks. |
9th Oct 2010 11:30am |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
Also check the air suspension compressor/ suspension units - you may have an air leak that is causing that compressor to cut in a lot. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
9th Oct 2010 12:06pm |
Fairly sure its not the compressor but will check. Seems work fine (touch wood).
9th Oct 2010 1:41pm |
Tried a quick drive with the AC off, still did it.
9th Oct 2010 1:43pm |
Here is the video
9th Oct 2010 1:52pm |
I have spent all afternoon looking on the internet about this issue.
9th Oct 2010 5:25pm |
Could it be a faulty MAF or a fault in the wiring to the MAF? |
9th Oct 2010 5:32pm |
