Home > Maintenance & Mods (L322) > How to remove top dash 2010 vogue se
roy rogers
England 2010 Range Rover SE 4.4 V8 Stornoway Grey
Hello All
I bought from powerful uk the piano black inserts now struggling to get top dash off to fit the two side inserts at the side of radio/infotainment system . In a recent post in car electronics it was mentioned about two hex screws under top vents I have found them and removed but can't figure out how to remove air bag housing behind / over CD player . There are also three hex screws behind the range rover badge which I have also removed there seems enough clearance to remove radio with out removing air bag housing but can't find all removel screws . Big Cry any ideas ?
Kind Regards
Paul
Post #312646 14th Feb 2015 7:23pm
Two 10mm headed bolts hold the airbag to the frame sir Thumbs Up
Post #312664 14th Feb 2015 8:57pm
roy rogers
Thanks for your reply , I see the bolts but not sure how to get to them
Post #312666 14th Feb 2015 9:04pm
Don't overky understand your dilema! If you can see them... Do you not have suitable tools?
Post #312702 14th Feb 2015 11:24pm
roy rogers
Yes I do have tools ,and can see them when looking through side panel but they behind CD player , and seem hard to get tools on , It got dark last night so will take some pics tomorrow thanks
Paul
Post #312721 15th Feb 2015 6:59am
Both gloveboxes need to come out (top one includes CD player) then you have access to the two bolts...
Post #312731 15th Feb 2015 9:39am
roy rogers
Thank you for that Smile is there wiki or posts on the removal of gloveboxs ?
Paul
Post #312735 15th Feb 2015 10:06am
3 million torx screws... That's all... Thumbs Up
Post #312747 15th Feb 2015 10:54am
roy rogers
Very Happy thanks for your help ,best get screwing then
Kind Regards Thumbs Up
Paul
Post #312751 15th Feb 2015 10:58am
