Home > Technical (L322) > FBH relay question |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3966 |
No relay involved.
31st Jan 2015 11:07am |
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 |
I thought it was permeant live, and then w bus for the control.
31st Jan 2015 11:08am |
mbmarkyb Member Since: 18 Jan 2015 Location: basingstoke Posts: 22 |
Found it in rave to thank you for posting. I think.I either have a ecu board problem on the fbh as it also suffers with fan being on when you.open doors etc or a pump or a connection . will see if I can access the pump and.test for power etc this afternoon |
31st Jan 2015 12:29pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
http://www.fullfatrr.com/forum/topic23111.html?highlight=paulb |
31st Jan 2015 1:32pm |
Thanks for the responses and links will get in touch with mike |
31st Jan 2015 8:37pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6712 |
Doh, sorry, misread FBH for FSR Got - 2017 SDV8 Autobiography in Loire Blue
31st Jan 2015 8:46pm |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
FBH fuel pump is not in the tank,its on a rubber bracket above and to the front of the tank
31st Jan 2015 9:28pm |
ta for info again. got the pump out . was just a mass of rust . tried on a 12v source and just click nothing tested connector and I have power . New pump ordered. I am still suspecting pub but will change this first |
8th Feb 2015 6:19pm |
the pump does just click once when you power it up
8th Feb 2015 7:04pm |
if that is the case then it maybe ok apart from one end of the metal pipe just broke off.
8th Feb 2015 9:14pm |
saw a few like this and still working
8th Feb 2015 9:19pm |
